14
In my understanding, in Newtonian mechanics if something has no mass it cannot be said to "exist" since it cannot possibly have energy or momentum and thus cannot participate in interactions or be detected.
I believed that this is also the case in relativistic physics with energy in place of mass. The complete absence of energy is only possible for a massless particle of zero momentum. The question is whether such particles "exist", i.e. affect physical processes in any way?
I always assumed that the answer is negative. On the other hand, consider the massless scalar field with creation operator $a^\dagger(\vec{p})$. Then the state $$a^\dagger(\vec{0})|0\rangle:=a^\dagger(\vec{p})|0\rangle\Big|_{\vec{p}=0}$$ does not look to me as flawed in any respect compared with the states of non-vanishing $\vec{p}$.
To summarize: is the concept of a massless particle with vanishing momentum meaningful experimentally or theoretically?
Edit: making it harder to ignore let's assume that the particle we've created above posseses an electric charge. As far as I am aware there is no principle prohibiting massless particle to carry a charge (even if it has zero energy).
The concept of a particle with exactly zero energy is rigorously meaningless.
The issue is that the quantum field is not an operator, it is an operator-valued distribution. Therefore, strictly speaking, you can't apply $\phi(x)$, $a(p)$ or $a^\dagger(p)$ to anything, but you have to smear these things out. Strictly speaking, $\phi(x)$ doesn't even mean anything, as distributions live on the space of test functions, not on spacetime itself. Therefore, you can't actually speak of the state $a^\dagger(p)\lvert \Omega \rangle$, but should speak about something like $\int a^\dagger(\vec p) f(\vec p) \mathrm{d}^3p \lvert \Omega \rangle$ for some "profile" $f\in C_c^\infty(\mathrm{R}^3)$, which does not possess a definite energy, in particular not zero.
This is analogous to saying that the QM momentum eigen"states" $\lvert p \rangle$ for a free Hamiltonian do not lie in the Hilbert space of states, but only the wavepackets of uncertain momentum constructed from them.
ACuriousMind
  • 132,081
The emission of massless particles (e.g. photons) with zero momentum (or momentum tending towards zero) in the rest frame of a charged particle is called collinear emission.
Collinear emission is somewhat problematic for massless particles, because it results in a so-called IR divergence that cannot be removed by renormalization (cf. UV divergences). The resolution to this problem is resolution: the collinear emission is experimentally indistinguishable from the case in which there was no emission, as one cannot detect arbitrarily low-energy photons. When making a prediction, one must sum the differential cross-sections for collinear emission and no emission, which are both divergent. The sum results in a cancellation of the divergent terms.
So, does the zero energy particle exist? This really depends on what you mean by exist. I would say that the particle didn't exist, because the of arbitrarily low-energy photons cannot be distinguished from no emission at all. On the other hand, though, without them, the IR singularities wouldn't cancel, so the inclusion of real, zero-energy emission is important.
innisfree
  • 15,425
-2
Do particles with exactly zero energy exist?
No.
A photon has no mass, but it does have energy-momentum, it does participate in interactions, and it can be detected. It exists. Perhaps the word "mass" is the issue here. When we say mass without qualification it's assumed to mean "rest mass". The photon has no rest mass, but it does have a non-zero "active gravitational mass" and a non-zero "inertial mass".
They don't exist. Nor do any zero-inch rulers.
I always assumed that the answer is negative. On the other hand, consider the massless scalar field with creation operator...
The problem here is that the creation operator is an abstract mathematical "construct" that substitutes for a clear physics understanding of how say gamma-gamma pair production actually works. The gamma photons do not pop out of existence courtesy of an annihilation operator, and the electron and positron do not pop into existence courtesy of a creation operator. Have you ever read the given explanation for this? "A photon can, within the bounds of the uncertainty principle, fluctuate into a charged fermion–antifermion pair, to either of which the other photon can couple". Pair production occurs because pair production occurs. Spontaneously, like worms from mud. As if a 511keV photon is forever fluttering along turning into a 511keV electron and a 511keV positron in defiance of conservation of energy, which obligingly turns back into a single 511keV photon in defiance of conservation of momentum, which nevertheless manages to propagate at c. It's tautological garbage I'm afraid.
No.
Making it harder to ignore let's assume that the particle we've created above possesses an electric charge. As far as I am aware there is no principle prohibiting massless particle to carry a charge (even if it has zero energy).
There is. You can't have charge without mass. Think of photon momentum as resistance to change-in-motion for wave propagating linearly at c. Then remember your pair production, and the wave nature of matter, and that in atomic orbitals electrons "exist as standing waves". And think of magnetic moment and electron spin and the Einstein-de Haas effect which "demonstrates that spin angular momentum is indeed of the same nature as the angular momentum of rotating bodies as conceived in classical mechanics". Then think of electron mass as resistance to change-in-motion for a chiral "spinor" wave going round and round at c, whereupon the electromagnetic field-variation now looks like a standing field. Standing wave, standing field. The label we apply to this standing field, is charge.
John Duffield
  • 11,381
