I'm watching some Physics lectures on the internet by Leonard Susskind:
http://www.youtube.com/watch?v=pyX8kQ-JzHI&feature=BFa&list=PL189C0DCE90CB6D81&lf=plpp_video
In this lecture, and also in Wikipedia and other places phase space is described as the space of all the states we need to know to determine the configuration of the system infinitely into the future.
But I don't understand how is position and velocity enough to determine this, what about forces?
Let's say we have a particle and we want to know where it will be in 10 seconds, we obviously need it's starting position, it's starting velocity and also all the forces acting on it, or it's acceleration.
Where is my misunderstanding?
fiftyeight
  • 1,075
If you are looking for a detailed answer as to why in general Lagrangians depend only on first derivatives, then you should read the answer in this question, as Qmechanic rightfully said.
However, I suspect that you are asking something else:
Given that the equations of motion depend only on first derivatives (like Newton's law), why aren't second derivatives necessary in order to completely describe the state of the system?
The answer (if this is indeed your question) is that the accelerations can be computed from the first derivatives and the coordinates.
To make things concrete, if your system is described by a vector $\vec X(t)$, and the equations of motions are $$\partial^2_t\vec X=f(\vec X,\partial_t \vec X)\ ,$$ then knowing $\vec X$ and $\partial_t \vec X$ at $t=0$ completely determines the state of the system at later (or earlier) times*. The function $f$ describes a flow in phase-space. This means intuitively that if you place yourself somewhere in phase-space (i.e. - you know $\vec X$ and $\partial_t \vec X$), $f$ tells you where to flow to, and the future (and history) of your system is completely determined.
*I assume for simplicity that $f$ is nice. There may arise singularities of all kind of sorts, and you can read about it in any ODE textbook, and also here and here.
yohBS
  • 1,790
