An observation more than a question.
Take any function $f$ (additional hypotheses may follow) and evaluate it on any two points $x_1, x_2\in\mathcal{D}_f$. Define then the sum of these two points as the value the function takes on the sum of the inverse values, namely $$ x_1 +_f x_2 = f\left(f^{-1}(x_1)+f^{-1}x_2\right)\equiv F\left(f^{-1}(x_1),f^{-1}(x_2)\right) $$ where essentially the idea is to rewrite the right hand side in terms of each of the singular values $f^{-1}(x_i)$. This has been triggered by the following explicit example with $f=\tanh$, which gives back the relativistic composition of velocities $$ x_1+_f x_2=\tanh\left(\tanh^{-1}(x_1)+\tanh^{-1}(x_2)\right)=\frac{x_1+x_2}{1+x_1\cdot x_2} $$ which reads nothing but ($c=1$) $$ u+_fv=\frac{u+v}{1+uv} $$ Question is: have you ever come across any other example where the above can be useful and generalised?
EDIT: I have adjusted the notation to make it more precise following the comments below.
gented
  • 6,058
Let $X$ be a set with a binary operation $\star:X\times X\to X$, which could be a group structure or whatever you want. Let $f:X\to Y$ be a mapping to some other set and let $F(x,y) := f(x\star y)$ (your middle expression is this one with the operation +). If $f$ is sufficiently nice, e.g. a bijection, then your construction transports the binary operation from $X$ to $Y$.
In your example, for a given velocity $v\in(-1,1)$ we have a boost $\Lambda(v)\in O(1,1)$, giving us the bijection $f = \Lambda^{-1}$:
$$\Lambda^{-1}: O(1,1)\to(-1,1)$$
The group structure of $O(1,1)$ is transported to the interval $(-1,1)$ by this map:
$$u\star v = \Lambda^{-1}(\Lambda(u)\Lambda(v)) = \frac{u+v}{1 + uv}$$
When both already come with their binary structure so that $f$ is an isomorphism we get the most trivial case, in which you can use $f$ to choose to use the group operation in the group (or whatever it is) it is easiest in, this is often done to turn multiplication into addition through $\exp$ and $\log$.
A less trivial example of some interest in physics is given by the Baker-Campbell-Hausdorff formula, in which $f = \exp$, the exponential map $\mathfrak g\to G$ of a Lie algebra to the Lie group it is the tangent space of (at the identity). Strictly speaking this would correspond to a map $Y\to X$ in the preceding but that doesn't really change anything essential, only its inverse may not be defined on the whole of $G$.
This map has a lot of structure, but in general it is not a homomorphism. The formula defines a map $Z$ of two Lie algebra elements $X,Y\in\mathfrak g$ that map to an element $Z(X,Y)\in\mathfrak g$ whose image under $\exp$ is the product $\exp(X)\exp(Y)\in G$ where defined.
Explicitly, let $x,y\in G$, write $X = \log(x), Y = \log(y)$, then
$$xy = \exp(X)\exp(Y) = \exp Z(X,Y)$$
(so $Z$ is our binary operation and $F = \exp\circ\, Z$) where
$$\begin{split}\log(xy) = Z(X,Y) &{}= \log(\exp X\exp Y) \\ &{}= X + Y + \frac{1}{2}[X,Y] + \frac{1}{12}\left ([X,[X,Y]] +[Y,[Y,X]]\right ) \\ &{}\quad - \frac {1}{24}[Y,[X,[X,Y]]] \\ &{}\quad - \frac{1}{720}\left([Y,[Y,[Y,[Y,X]]]] + [X,[X,[X,[X,Y]]]] \right) + \cdots\end{split}$$
In this way you can obtain or approximate the product of two elements in $G$ from the Lie algebra, which often has advantages.
doetoe
  • 9,484
Another important example: the Pythagorean Sum defined by $f(x) = \sqrt{x}$.
As Doetoe says, you're simply transporting the binary operation + to the domain of $f$ if $f$ is e.g. bijective. If your domain is a real interval, your question actually describes the following:
Which operation is calculated by the addition of affine co-ordinates implemented by the slide action of a slide rule with a scale defined by $f$?
In this context the function $f(x)$ defines what number sits at a distance $x$ along the scale and $f^{-1}(y)$ defines the distance along the scale from the scale's beginning to the point where $y$ lies on the scale. So in the basic slide rule scales, we have $f = \exp$ and then the main (ABCD scales) are a physical embodiment of the isomorphism between the multiplicative Lie group of positive reals and the additive real Lie group: $f$ is here the isomorphism $\exp:\mathbb{R}\to\mathbb{R}^+$ so that $x\,y = x +_{\exp} y = \exp(\exp^{-1}(x) + \exp^{-1}(y))$. Doetoe's example of the Campbell Baker Hausdorff formula generalizes the $\exp$ notion to noncommutative Lie groups.
The only other operation to my knowledge that was done on real slide rules that makes use of your pattern was the Pythagorean sum, where we put $f(x) = \sqrt{x}$. The $P$ and $Q$ scales of some of the Hemmi-Sun Japanese slide rules encoded this pattern. The number $x^2$ lies at distance $x$ along the $P$. You then bring the zero on the $Q$ scale to this point, and the number $y^2$ lies at a distance $y$ along this scale. When you add the two and read back on the $P$ scale, you're looking at the number $z$ such that $z^2 = x^2 + y^2$: so the $P$ and $Q$ scales were used to work out the hypotenuse length from the two other sides of a right angled triangle. Useful for trigonometry and electrical calculations, which these particular rules were designed for. So Pythagoras's theorem is an important example of your pattern.
There is a virtual slide rule with these $P$ and $Q$ scales at:
Mark Armburst, Virtual Hemmi 153 Slide Rule at Mark's Math
To see the $P$ and $Q$ scales you need to push the "Flip to Other Side" button.
To my knowledge, no slide rule gave the calculation with $f=\tanh$, which would have been useful for special relativistic calculations! Albert Einstein was known to have used a Nestler 23R rule, which was very basic.
Selene Routley
  • 90,184
  • 198
  • 428
