In this link, one of the answers contains the statement
If you examine the space-time near a finite area quantum black hole, you will see an approximate AdS space.
Presumably "approximate" means this is only true to some order in the distance from the horizon ? Could someone outline where the result comes from, or provide a reference.
twistor59
  • 17,244
  • 56
  • 84
The answer you quoted was invalid in most respects, including this one. The quantum character of a black hole has nothing to do with the AdS geometry; the AdS geometry is the near-horizon geometry of a classical black hole (or black brane). Which black hole? It has to be an extremal black hole, i.e. it must have the maximum value of a charge or angular momentum that is allowed for the given mass (or mass density, in the case of black branes).
For a black $p$-brane which is extended in time as well as $p$ additional spatial dimensions, one obtains $AdS_{p+2}$. For example, one may get an $AdS_2\times S^{d-2}$ from the near-horizon geometry of extremal black holes in $d=4$. See the derivations and comments e.g. around pages 57 and 104 in
http://arxiv.org/abs/hep-th/9905111
or search "near-horizon [geometry]" in this paper or another introduction to AdS/CFT. Black holes that are non-extremal have a finite volume of the region near the horizon and quantum phenomena don't change anything about this fact. The extremality is needed for the infinite volume – and AdS spaces have an infinite volume. The derivation of the near-horizon limit of a black hole metric is a purely classical, geometric procedure: one neglects some subleading terms in the metric tensor and only keeps the leading ones (which dominate for a small difference $\Delta R$ from the horizon, relatively to the black hole radius), just like you would expect.
Luboš Motl
  • 182,599
The approximation is within purely classical gravity, and the parameter in which it is approximate is distance from the horizon. It is the expansion of a spacetime near the horizon of an extremal black hole to leading order in the ratio of the distance from the horizon to the radial parameter of the black hole. The reason for saying "quantum" in the answer is because the near-horizon description is most useful for cases where the near horizon behavior is the same as the behavior of bound strings, which are described by a pure gauge theory living on the branes which make up the quantum degrees of freedom of the model black hole. This case is called AdS/CFT.
When a black hole is not extremal, like a normal Schwarzschild black hole, the horizon is locally flat. So if you zoom in close to a patch of the horizon, you find ordinary Minkowski space, except that the external time coordinate becomes a Minkowski angle coordinate, just like Rindler space.
To see this formally, consider a Schwarzschild metric in a radial coordinate parametrized by u so that the usual radial coordinate r is given by $r=2M+u^2$
$$ -{u^2\over 2M + u^2 } dt^2 + {2M+u^2\over u^2} dr^2 + (2M+u^2)^2 d\Omega^2$$
Replace $dr$ by $2u du$ and consider u small, so that the metric becomes to leading order
$$ -{u^2\over 2M} dt^2 + 8M du^2 + (2M)^2 d\Omega^2 $$
The result is the Rindler space metric in the t,u coordinates, copied over a 2d sphere. Since the r,t coordinates are perpendicular to the sphere, expanding the sphere in locally flat coordinates, you recover 4d Minkowski space in Rindler form, at every local patch of the sphere. The $d\Omega^2$ part becomes $dy^2 + dz^2$ near a given point on the sphere (they are all the same), and then the usual coordinate change from Rindler space to Minkowski coordinates (with an additional rescaling to get rid of the 2M factor) works to show that the spacetime is locally Minkowski, i.e. that the horizon is not a special singular place.
The easiest extremal limit is the Reissner Nordstrom black hole:
$$ds^2 = - f(r) dt^2 + {1\over f(r)} dr^2 + r^2 d\Omega^2 $$
With $f(r) = 1-{2M\over r} + {Q^2\over r^2}$. In this case, extremality is Q=M, so that $f(r) = (1-{Q\over r})^2$. Now the horizon is at r=Q, and the integral of the distance ds from r=Q out gives infinity. This is the "infinite volume" business Lubos mentions--- it is just the infinite distance to the horizon, times the area of the sphere. It does not imply that objects cannot cross, because the horizon goes out noncausally to meet finite mass objects in finite time. Only infinitesimal test particles take forever to fall in, finite objects fall in in finite time (and I believe also fall back out in finite time, but that's another story).
Expanding r=Q+u, $f(r) = u^2/Q^2$ to leading order, and you get
$$ ds^2 = - {u^2\over Q^2} dt^2 + {Q^2\over u^2} du^2 + Q^2 d\Omega^2 $$
The first part is now a locally curved 2d spacetime, and the second part is the metric of a sphere of radius Q. The curvature of the first part must be constant across the sphere by symmetry, and it must be constant in u, since you are zooming into a small u limit, where the curvature of the radial sphere becomes constant, so that the curvature of the u part must be the negative of this by Einstein equation property of vanishing Ricci curvature. So it must be an AdS space.
But it is good to verify this explicitly. Using the logarithmic coordinate $x = Q log u$, and rescaling t by Q, the radial metric becomes
$$ ds^2 = - e^{-{2\over Q} x} dt^2 + dx^2 $$
This is now obviously homogeneous because a shift in t does nothing, while a shift in x is compensated by a rescaling of t. The curvature may be calculated quickly usinf the quick-and-dirty method described here: Ricci scalar for a diagonal metric tensor
$$ g_{\mu\nu} = - e^{- 2\alpha x} l_{00} + l_{11} $$
Where $\alpha = 1/Q$, differentiating
$$ \Gamma_{\xi,\mu\nu} = -\alpha e^{-2\alpha x} (l_{001}+l_{010}+l_{100})$$
$$ \Gamma^\xi_{\mu\nu} = -\alpha (l^0_{10} + l^0_{10} ) + \alpha e^{-2\alpha x} l^1_{00}$$
Which gives the differntiated part of the curvature
$$ \Gamma_, = 2\alpha^2 e^{-2\alpha\nu} l_{00} $$
and the product part
$$ \Gamma\Gamma = -\alpha^2 e^{-2\alpha x } l_{00} - \alpha^2 l_{11} $$
So that together they give the Ricci
$$ R_{\mu\nu} = -\alpha^2 g_{\mu\nu} $$
This is a constant negative curvature space, an AdS space.
Although I used the most trivial example of the 4d Reissner Nordstom solution, the argument is completely generic, it applies for all extremal black holes, where you have a nonvanishing curvature in the near-horizon limit. All these objects have an infinite distance to the horizon, and they all reduce to a homogeneous sphere or sphere-quotient times an AdS space in the transverse coordinates. The generic near-horizon behavior of black hole solutions is a foundation stone of AdS/CFT--- the near horizon degrees of freedom are the stuff that is stuck to the black hole, which are described in the weak coupling string theory by those strings that are stuck to the brane. The low energy limit of strings stuck to branes are necessarily described at low energy by the appropriate gauge theory.
