Are there physically realizable dynamical systems where the true trajectory is not a minumum action trajectory?
Formally, Lagrangian mechanics only requires that the trajectory be an extremum (or saddle point?), but all of the cases that I'm aware of, it is, in fact, a minimum. Are the other possibilities relevant for modelling any physical systems?
Dave
  • 4,203
As demonstrated in this paper, the trajectory can never maximise the action but can in fact lie on a saddle point in cases where the potential has the appropriate spatial variation (at least partially repulsive) and where the final state is taken sufficiently far 'downstream' (beyond what these authors call the 'kinetic focus').
tok3rat0r
  • 799
Not to mention, there are cases where the local extremum of the action isn't a physically realiziable path. Consider the plane with all the points satisfying $y > |x|$ removed. now, consider a start point of $(-2,1)$, and an end point of $(2,1)$ on this manifold, with the Lagrangian $\frac{1}{2}m\left({\dot x}^{2} + {\dot y}^{2}\right)$. Clearly, the minimum of the Lagrangian will take the particle on a path that leaves the manifold.
