First some assumptions.
1) Photons travel at the speed of light. 2) From the photon's reference spacetime is contracted to 0 length in the direction of photon travel. 3) From the photon's reference it is emitted and absorbed at the same time and in the same place.
Now imagine a setup with 1 emitter and 2 detectors (E, D1, D2). E emits photons toward the center of D1. D2 is directly behind D1 in the direction in which E emits (D1 is in the line-of-site of E, D2 is hidden from E behind D1.
E -> D1 D2
From our frame of reference photons are emitted and always absorbed by D1.
From the photon's reference, aren't the emitter and detectors sitting in the same place in its perceived 2D space? Wouldn't it then be equally valid for the photon to be absorbed by D2, or both D1 and D2? Maybe neither? Does contracted spacetime maintain some sort of z-order?
It's been my understanding that when things happen doesn't remain constant between reference frames, but the effects, what actually happens does.
Is there a paradox here or am I looking at it wrong? Is it ever valid to ask what happens in an external frame of reference?
Scott
  • 23
Let's start with your assumptions:
Right. No problem with that.
Wrong. The photon doesn't have any kind of reference frame. To appreciate why, imagine you're travelling at the speed of light. We know you can't actually do this, but just imagine it. Some would say that in your reference frame everything happens at once. But I know your course, and I can nudge an asteroid into your path: BLAM! It's game over for you. You didn't see the asteroid because you don't see anything when you're moving at the speed of light. Light would have to move faster than light for that, and it doesn't. So you don't see everything happening at once, you don't see anything. Or think anything either. You're a popsicle.
Wrong. Like I said, the photon doesn't have any reference frame. Its wavelength isn't length-contracted to zero either. It gets emitted, it moves through space at the speed of light with its E=hc/λ wave nature, then it gets absorbed. And these three events didn't happen at the same time. Note that I measure my time using my optical clock, which has light moving inside it. The elapsed time relates to how much the light has moved.
Now imagine a setup with 1 emitter and 2 detectors (E, D1, D2)... ...From the photon's reference, aren't the emitter and detectors sitting in the same place in its perceived 2D space?
No. It doesn't perceive anything. Just like you didn't perceive that asteroid.
No.
Space doesn't change one iota just because you changed your speed through space. Nor do the things in space. Instead you change, along with your measurements of space and time and things.
You're looking at it wrong I'm afraid.
Yes, that's no problem. The problem comes when you think there is a frame of reference when actually there isn't. And you are not the only person who has this problem.
John Duffield
  • 11,381
As John Duffield pointed out in his answer, there is no reference frame in which the photon is at rest. This is the simple reason why most parts of your statements do not make sense.
Still, there is an interesting perspective to the issue you raise: Normally one considers the events or states "photon emitted", "photon is traveling", "photon absorbed" as well separated, and, indeed, from our perspective (from the perspective of a real frame of reference), there can be a large amount of space and time between the emission and the absorption of a photon. Only the spacetime interval which separates these events is 0. So guess, some photon is emitted from a star in the Andromeda galaxy and is on the way to our planet. Isn't there plenty of time or occasion to distract this photon from its original way? Not really. Guess we want to decide how and if to detect a photon while it is on its way. That means that first we need to get the information that the photon is on its way (has been emitted and not absorbed yet) and then we need to decide if and how to detect it. Such an experiment cannot be executed since it would be necessary that the information that the photon is on its way gets to us before the photon arrives at our location. And this would require the information to travel faster than light.
So, indeed, the absorption and emission events seem to be tightly connected. There is not much which fits in between even if these events are separated by a large distance in space and time from our perspective. On the other side, there is not really a frame of reference where the order of these events is reversed. The order remains well maintained.
willyW
  • 171
The photon does not have an rest frame because that would imply it's velocity is 0, when by postulate it must be moving at C in all frames. Rather pointless to wax on about not experiencing any time or what not.
CStarAlgebra
  • 2,845
Your question has nothing to do with the (hypothetical) photon's reference frame.
Even if the spacetime interval of lightlike movements is reduced to zero, the order of events is persisting - In the same way as when you cover one sheet of paper by another, you cannot reach the hidden sheet even if their respective distance approaches zero.
Edit: By the way, there is no zero distance: the spacetime interval is reduced to zero, but not the space interval. Remember that length contraction is only perceived by the moving frame, in this case by the (hypothetical) reference frame of the photon. But from the point of view of any other frame the distance is not zero.
Moonraker
  • 3,173
