Consider Wick's rotation from Minkowski to Euclidean space in QFT. What is the connection between $O(4)$-invariance in Euclidean space and Lorentz invariance in Minkowski space? If we define a quantity which is $O(4)$-invariant in Euclidean space, is it guaranteed, that it will become Lorentz invariant after analytical continuation back to Minkowski space?
Janosh
  • 1,294
Yes, you are right. In Minkowski space $(t,x,y,z)$, the space-time interval: $$ds^2=dt^2-dx^2-dy^2-dz^2$$ If we define $t=-i\tau$, then we will have $$ds^2=-d{\tau}^2-dx^2-dy^2-dz^2=-(d{\tau}^2+dx^2+dy^2+dz^2)=-ds_E^2$$ where $ds_E^2$ denotes the Euclidean interval in $4D$ Euclidean space $(x,y,z,\tau)$.
As you can see, once the transformation between $t$ and $\tau$ is fixed, we can go back and forth between the two representations which are invariant under Lorentz and Euclidean rotations respectively.
M. Zeng
  • 2,421
  • 19
  • 32
Three of the angles from the $4$-dimensional rotations, $\mathrm{SO}(4)$, become imaginary, leading to the group called the Lorentz group. The imaginary angles correspond to a transformation called a boost, and the angles are called rapidities. The Lorentz group, at least the proper orthochronous part of it, has the property of being broken into three regions that are mutually isolated and correspond in Minkowski space to the surfaces at $\tau = \sqrt{(ct)^2 - r^2} = 1$ with $t > 0$, $\tau = 1$ with $t < 0$, and $\tau = \sqrt{-1}$. That is, those three hyper-surfaces cannot be reached by a continuous path defined by changing $3$-d rotation angles and boosts.
Sean E. Lake
  • 22,927
