In this YouTube video water ripples start out with a wavelength of, say, 10 cm at the outer edge and they end up with a wavelength of about 30-40 cm towards the end of the video. Why does this happen, in simple, plain English? I can see here wave equations that produce the same result in simulations, but the equations don't give me a "feel" for why this happens. Intuitively, I'd expect the opposite: when water ripples spread out, I'd think they encounter "resistance" from the medium, so if anything, I'd expect the wavelengths at the front to decrease or "bunch up".
Several things happen with ripples.
First - they are comprised of different wavelengths. That may be hard to explain in plain English, but basically the only way that a wave can have a single wavelength is when it goes on for all infinity. A short "wave packet" must contain different wavelengths.
Next - the speed of propagation of these different wavelengths is not constant: this means that the "packet" of waves will spread out over time. Imagine the start of a running race. Initially all the runners start together, but since some are running faster than others, after a while the "field" spreads out.
As a further complication, different wavelengths will be attenuated by different amounts - the high frequency ripples are attenuated more strongly over the same distance. This means that the ripples will look "longer" as they travel further - the shorter components have been damped.
- 119,981
As stated in previous answer,many things happen in water ripples.But a major reason for increment in wavelength is loss of energy as the wave progresses due to non ideal conditions.Since wavelength is inversely proportional to energy of wave,as energy decreases,wavelength increases.Hope this helps :-)
- 93
