The metric of the BTZ Black Hole is given by $$ ds^2 = - N^2 dt^2 + N^{-2} dr^2 +r^2(d\phi + N^\phi dt)^2 $$ with $$ N^2 = -M+ \frac{r^2}{l^2} + \frac{J^2}{4 r^2}, \ \ \ \ \ \ N^\phi = -\frac{J}{2r} $$ The $g_{rr}$ component of the metric is singular at points where $N^2=0$, yielding the horizons $r_\pm$ $$ r_\pm = \sqrt{ \frac{Ml^2}{2}\left( 1 \pm \sqrt{1-\left(\frac{J}{Ml}\right)^2} \right)} $$ Then for these $r_\pm$, the metric component $g_{tt}$ does not vanish but becomes $$ g_{tt} =\frac{J^2}{4r_\pm^2} $$ Now the perscription I learned to find a Hawking Temperature at a horizon (e.g. Schwarzschild BH) is you expand the Wick rotated metric ($t\to i\tau$) around the solution where $g_{\tau\tau}$ vanishes, find the metric is actually flat at this point, and impose $\tau$-periodicity such that there is no conical singularity at the horizon. This period is then the inverse Hawking temperature $T_H^{-1}$ .
I don't see any singularities in the $g_{\tau\tau}$ component right now so no conical singularity will appear, and I don't know how to interpret this. Does this mean there is no restriction on $T_H$ and the $\tau$ periodicity is free? Or is my way to calculate it somehow not applicable to BTZ horizons?
