The cosmological constant seems to be normally described as an energy (repulsive force, Dark Energy) of Space-Time. I was just wondering, if we were to interpret the cosmological constant as being geometrical (i.e. put it on the LHS of the equation), how would it be described. Would it correspond to an exponential increase in the 'stretch' of Space-Time from any given reference frame, or is it more subtle than that?
If we were to interpret the cosmological constant as being geometrical (i.e. put it on the LHS of the equation), how would it be described?
Dark energy is said to be responsible for the increasing expansion of the universe, so let set that aside. Let's focus on the cosmological constant, which is "the value of the energy density of the vacuum of space". Then let's think how the expanding universe is likened to an inflating balloon:
enter image description here Image courtesy of the one-minute astronomer.
Imagine a balloon in a vacuum. The pressure of the air inside is balanced by the tension in the skin, and there's two ways to make it expand. One way is to blow more air into the balloon. However the dimensionality of energy is pressure x volume, so doing this is in breach of conservation of energy. But there is another way. Not by increasing the pressure, but by reducing the tension. You make the skin weaker. This sounds strange until you see the obvious: make it a bubble-gum balloon. As the balloon expands, the skin gets thinner and weaker, and less able to resist the expansion. So it expands further, so the skin gets weaker, and so on. The pressure drops, the volume increases, but energy is conserved.
Now take a look at page 5 of http://arxiv.org/abs/0912.2678 where Milgrom mentions the strength of space. Think in terms of the tensile strength of space, and it's something like our balloon analogy, but for a 3D bulk. Then go back to Einstein, who introduced the cosmological constant to stop his universe collapsing. That was akin to a pressure, but the cosmological constant is described as a negative pressure. And negative pressure is tension. So in my humble opinion the cosmological constant is described as a tension, rather ike the tension of the bag model. The tension is reducing, along with the energy density. And because the cosmological constant is "the value of the energy density of the vacuum of space", it isn't constant after all.
As to how it might end, there's something in this little article by Phil Plait that bothers me. Bubble-gum bubbles don't always end well.
John Duffield
  • 11,381
