Suppose I have a solar-sail-powered starship flying directly away from a star. The sail is flat and perpendicular to the direction of travel. Now, in order to make the trajectory more stable (we think), we make the ship spin around its center of mass and the axis aligned with motion.
- Would the sail's spin cause a transfer of linear/angular momentum between the sail itself and the impacting radiation, actually causing the trajectory to deviate from the original line?
My guess in this case (perpendicularly hitting radiation) would be NO, as any effect on one part of the sail would be countered by those on the opposite part (if radiation is uniformly distributed).
But then, what would happen if the ship was flying across a star system with its sail set at an angle, i.e. only partially facing the star (in this case the side of the sail closer to the star and moving, say, up would receive more radiation than the opposite one, moving down and farther away)? Would there be linear momentum exchange here, causing the trajectory to veer (like a spinning ball moving through the air)?
What would happen in the case of pure electromagnetic radiation vs. the case where we have massive particles in the star wind?
