If $g$ is the acceleration due to gravity and $\beta$ is a known value, solve for the time $t$ it takes an object to reach a given velocity if the acceleration of the object is given by
$$a(t) = g - \beta v(t)$$
We know that when $a(t) = 0$, $v(t) = \frac{g}{\beta}$, and when $t=0$, $v(t)=0$
A possible solution
We can solve this first-order linear ordinary differential equation with a solution that looks somewhat like
$$v(t) = c_1 e^{-b t}+\frac{g}{\beta}$$
where $c_1 = -\frac{g}{\beta}$
We can solve for $t$ from there.
Is there a (simpler) way to solve this problem without using differential equations?
WHY
  • 113
In reality you have $a(v) = g - \beta v$ and you want $v(t)$ and $x(t)$. This can be achived with direct integration, instead of coefficient matching and diff. equs.
$$ t = \int\limits_0^v \frac{1}{a(v)}\,\mathrm{d}v= \int\limits_0^v \frac{1}{g-\beta v}\,\mathrm{d}v = -\frac{1}{\beta} \ln \left(1- \frac{\beta v}{g} \right)$$
or
$$ v(t) = \frac{g}{\beta} \left(1 - \mathrm{e}^{-\beta t} \right)$$
Now
$$ x(t) = \int\limits_0^t v(t)\,\mathrm{d}t =\frac{g}{\beta^2} \left( \mathrm{e}^{-\beta t} + \beta t - 1 \right)$$
Alternatively you can use directly $$x = \int \limits_0^v \frac{v}{a(v)}\,\mathrm{d}v$$
For more details see https://physics.stackexchange.com/a/15620/392
John Alexiou
  • 40,139
