-1
Stimulating water with two long straight bars one could produce linear waves. Having the right distance between the bars and the correct frequency of the steady system we get in the middle between the two bars complete destructive interference. In an ideal case the energy provided by the bars will be fully dissipated into chaotic heat energy of water molecules.
Thinking about to do a similar experiment with light, we get in trouble. First, sending crossed light beams normally do not led to a destructive interference, they are not interacting, or in the case of high energy photons it could lead to pair production. But production of a bigger amount of photons of lower energy (IR) is not imaginable. Dissipation does not take place.
Is it common to work in double slit argumentation with destructive interference arguments too? Young has done so. Do we too?
HolgerFiedler
  • 10,980
There are two ways to look at light, classical and quantum mechanical.
Electromagnetic waves given by the classical solutions of Maxwell's equations will have interference patterns as predicted mathematically from the sinusoid form of the solutions.
Are we working in the double slit argumentation with destructive interference arguments too? Young has done so. Do we too?
At the level of classical solutions there exists a corresponding formulation that does depend on the way the energy of the wave is deposited on the screen.
classical double slit
Two slits are illuminated by a plane wave.
The interference pattern is predicted and observed. It It is not destructive interference as in the case of sound waves, but the mathematics are the same. The wave deposits more or less energy as it hits the screen according to the sinusoid solution of the problem.
Questions may arise if one goes to a quantum mechanical formulation, where the plane electromagnetic wave emerges from an enormous number of photons who carry the energy of the wave in a quantized manner. The whole though is consistent as the way the classical wave is built up by the individual photons is known and consistent between the classical and quantum mechanical formulation.
In conclusion.
a) In the classical case the constructive and destructive interference observed is modeled with waves that transmit the energy of the beam and they interfere with each other similar to other classical waves.
b) When going to the quantum mechanical framework of photons the interference , single photon interference too, is , is in the probability distribution which describes the individual photon's probability to hit (x,y) on the screen. Thus the wave is a probability wave in this case, not an energy wave as classically. The two frameworks have been shown to be consistent when a large number of photons is involved, as can be seen in the link given above.
anna v
  • 236,935
