Let $\phi$ be a scalar field in an interacting theory ($\phi^3$ or $\phi^4$, for example). If $|0\rangle$ is the vacuum of the interacting theory and $P^\mu$ is the four-momentum operator, we have that
$$\langle 0 | \phi(x) | 0 \rangle = \langle 0 | e^{-iPx} \phi(0) e^{iPx} | 0 \rangle = \langle 0 | \phi(0) | 0 \rangle $$
In chapter 5 of his QFT book, Srednicki says that
We would like $ \langle 0 | \phi(0) | 0 \rangle$ to be zero. This is because we would like $a_1^\dagger (\pm \infty)$, when acting on $|0\rangle$, to create a single particle state. We do not want $a_1^\dagger (\pm \infty)$ to create a linear combination of a single particle state and the ground state.
Here $a_1^\dagger (\pm \infty)$ is the creation operator $a^\dagger$ for a momentum $\mathbf{k}_1$ taken at time $\pm \infty$, which (according to the book) guarantees that the particle is located away from the origin. In other words, we define $|k\rangle = \lim\limits_{t \to -\infty} a^\dagger(\mathbf{k}, t) |0\rangle$.
It seems to me that Srednicki wants $\langle 0 | k \rangle = 0$, which sounds reasonable. But applying the LSZ formula for the special case of one initial particle and zero final particles, I get $\langle 0 | k \rangle = i (2\pi)^4 m^2 \langle 0 | \phi(0) | 0 \rangle \delta^4(k)$ (the $2\pi$'s might be off). This is nonzero only when $k^\mu=0$, a.k.a. never, since $k$ must be on shell. So why must we ask that the fields's VEV be zero, when it seems that $\langle 0 | k \rangle = 0$ anyway?
Javier
  • 28,811
I think I have hit upon the main reason, which in hindsight was really obvious. The assumption that the creation operators work as in the free theory (that is, that $a^\dagger(\pm\infty)$ won't create something that overlaps with the vacuum) is built into the LSZ formula, so it doesn't make sense to use the LSZ formula in this case; we have to go farther back. I'm still not clear on the relation between $\phi(0)$ and $a^\dagger(\pm\infty)$, since I would expect $\phi(0)$ to be related to $a^\dagger(0)$. Hopefully later I'll edit in something more complete.
Javier
  • 28,811
I can provide you with two reasons that I have learned in my studies. One $k^{\mu} $ need not be zero. The delta function implies $\omega_{k} = \tilde {k} $. This forces the single particle states to lie on the mass shell. Thus the only term that can be zero now is the vacuum expectation value. The reason this is zero is due to the assumption that the vacuum itself is Lorentz invariant. If this term was not zero then the vacuum expectation value would not be Lorentz invariant, which can be seen by allowing it to be nonzero and applying a Lorentz transformation to the field $\phi (0) $. I hope this helps, and good luck with your studies!
