Can anyone describe, (or point me to a paper that describes) time without referring to something else.
No. Nobody can. However I can point you to Presentism, and to A World Without Time: The Forgotten Legacy of Godel and Einstein. I can also point out that relativity accurately models our world using spacetime and worldlines and geometry, but that the map is not the territory, and that we live in a world of space and motion, not a block universe. I can also point you towards a clock, and tell you that the inner workings of that clock are quite aptly called a movement. I can then point out the patent blatant fact that a clock clocks up some kind of regular cyclical motion and shows you a cumulative display that we call the time. Whether it's a mechanical clock with a spring-driven rocker, a grandfather clock with a pendulum, a quartz wristwatch with a vibrating crystal, or any other kind of clock, that clock "clocks up" some kind of regular cyclical motion and shows you a cumulative display called the time. The big hand moves, and the little hand moves. That's no illusion. But it doesn't literally measure the flow of time like some magic cosmic gas-meter gizmo. Moreover I can hold my hands up a foot apart. Can you see that gap, that space between them? Yes. Now watch as I waggle my hands. Can you see that motion? Yes. Because space and motion are empirical. But can you show me time? No. You cannot. Nor can anybody else.
You've probably read Minkowski's introduction to Space and Time. He said "space for itself, and time for itself shall completely reduce to a mere shadow, and only some sort of union of the two shall preserve independence". I would venture to volunteer that had Minkowski lived longer, if he hadn't died before his time, he would have ended up writing a new paper. Called space and motion.
