I searched for my question and I found many results but all of them eventually try to solve something specific (like solving for the kinetic energy or finding when does the ball stop).
what I want is why does a ball roll at all?
Pretend I shot a ball and the ball started slipping on the ground, pretend it doesn't leave the ground and that the ground isn't incline.
Now I thought of friction force exerting a torque on the ball, if the force is $F_c$ then the torque should be:
$$\tau=u\times F_c\times r$$(There is no sin because $F_c$ is perpendicular to $r$)
The existence of $u$ is due to the fact that the force doesn't just rotate the ball but also slows it down.
What's missing in my assumption is the speed of the ball, it seems to me that the faster the ball the faster it rotates, I don't have an explanation for this because $F_c$ doesn't relate to velocity, $F_c$ is given by :
$$F_c=u_k\times N$$
where $N$ is the normal force and $u_k$ is the kinetic friction coefficient.
So what's a better explanation to this phenomena?
Edit
Something sparked in my mind, the ball doesn't just slip, in reality it bounces, we just don't see the bounces.
But I don't know how to put this into a good formula or explanation.
PS
what I mean by "the faster the ball" I mean its initial velocity (after shooting it) because the ball slows down.
niceman
  • 115
Consider two different regimes.
First - when the ball is still slipping, the relative motion of the ground and ball causes a force on the ball which (a) slows down the center of mass and (b) increases the angular speed. Once the ball rolls without slipping this force disappears.
Second - when the ball does not slip, the contact point must be stationary. This means that the angular velocity $\omega=\frac{v}{r}$. Now in that expression $v$ is the velocity of the rolling ball which is less than the velocity you launched it with because of what I wrote above. The time it takes to stop slipping depends on the initial velocity - as you said the torque is independent of the speed but the ball will just keep slipping (and rotating faster) as long as it takes to reach the point of no slip.
I wrote some earlier answers analyzing this motion in more detail - see for example here or there
Floris
  • 119,981
The ball rolls because: the friction present between the surface pushes the atoms/particles in contact with surface or ground backwards, hence with centre of mass moving in a direction, the ball's bottom surface(ie. The surface in contact) moves in opposite direction or backwards, causing the ball to roll. The ball slips because there is no friction that can push the bottom or atoms/particles in contact backwards. Thanks :)
Abhijeet
  • 235
Your assumption that the ball will be faster if it rotates faster has a very logical explanation and is completely valid. If your ball has a circumference C it will cover that distance with each rotation. Let us say your C was 1m and the period was 2 rps (revolutions per second) then your ball would cover 2 metres in 1 second. If your period is doubled to be 4 rps then your ball would cover 4 metres in one second. Its linear speed has also doubled.
Jaywalker
  • 2,413
