I reformulate the question a little bit because I feel that I was misunderstood. There are cosmic observations that tell us the universe seems to expand. It also seems to expand always faster (accelerating). I am missing the step of reasoning that, from the collected data, leads to the conclusion that it is certainly expanding. I mean: did they (the astrophysicists) checked that it can't be possible to see an "apparent expansion" even in a collapsing universe, before making their claim? Are there other different (from the redshift) observations that reinforce the conclusion of the expansion? Or: is this theory enough robust today, in order to exclude a possible "revolution" similar to the Ptolemaic/Copernican one (in the near future) ?
Thanks for explanations.
user6090
  • 1,446
I don't know of the statement claiming similarity between collapse/expansion but theory and experiment tell us that the almost universal red-shift we observe would be a blue shift; If the universe were collapsing.
Nic
  • 3,907
You are asking: is there any independent evidence, other than redshift, that the universe is expanding. This is a sensible question. In the old days, some people postulated "tired light", the theory that light just gets spontaneousy redshifted with time. This theory is not theoretically compelling, but it does ask that there should be independent evidence that the universe is expanding.
Big Bang nucleosynthesis
If the universe is actually expanding, and its not tired light, then there must have been a time when it was very hot. During this time, the temperature would decay in a very precise way, determined by General Relativity. Alpher and Gamow were able to calculate the amount of each element and isotope produced in this hot phase of the big band, within a few minutes of the birth of the universe.
The results are that 75% of the universe is Hydrogen, 25% is Helium, and a precise calculable trace amount is Deuterium, Lithium, Beryllium, He3. These abundances very across more than 5 orders of magnitude, and they are crazy numbers which are very sensitive to exactly how much matter is in the universe, and the precise masses of the fundamental particles.
These calculations match the observed abundances of H,He, Li, and the trace elements, with tiny residual errors. This is very strong evidence that the universe used to be hot.
Cosmic Microwave background
The Cosmic microwave background is relic radiation from the big bang. Tired light can account for the redhsift, perhaps, but it would not explain why at the edge of the visible universe we see a residual radiation which is at a definite temperature which matches observations.
This is also compelling evidence for the hot big bang. Further, the anisotropies in the microwave background are correctly predicted by inflation, using the observed abundances of normal and dark matter, inferred by other means. The accelerated universe is also in accordance with the cosmological constant required for inflationary theory to match observations. The detailed distribution of the temperature deviations of the microwave background would require an unbelievable conspiracy of tired and conspiratorial light to reproduce.
Structure formation
The theory of the big bang also predicts the formation of large-scale-structure in the universe, which is as expected, with simulations matching observations of the gap-structure and filaments in the large-scale universe, from the initial seed provided by inflation. These predictions are further confirmation of the circle of ideas.
Some of the most obvious signs of a universe expanding from a big-bang is that far away objects are more poorly developed than closer objects.
Is it possible that everything is wrong?
It is not realistically possible that all this is wrong, because the evidence was already too great to deny before the modern revolution in cosmology, and it has gotten much better.
-1
Why does anybody expect overall blueshift in a collapsing universe? I would expect redshift as well:
The universe consists already of a giant central black hole attracting our milky way and all other galaxies. The observed red shift can be explained by the 1/r² law of gravitation: galaxies that are nearer than our one to the central black hole have higher speeds towards it than we have. So we see them moving away from us. Galaxies that are further away from the central black hole than our one don't move so fast towards it as we do. So looking at them we see them escaping from us as well. The black hole and our distance to it are so big, that the field gradient is quite low, so we experience no tidal forces. Adjusting Newton's 1/r² law by Einstein's general relativity field equations does make a big difference to this model. The general pattern of galaxy motion relative to each other remains the same.
How can these claims be verified? Here is the principle algorithm. It can be implemented and executed even on a PC:
Take all recorded quasar spectra from the known quasar catalogs. Normalize their spectra to zero red shift. Compare each spectral signature which each other. Try reasonable compensation for differences according to dust or other noise adding effects. If you find two identical or similar ones, check the respective quasar's positions. If their angular positions differ by several degrees, you have some evidence. Because you found the same quasar twice: Once seen in direct (curved) line, and once its light wrapped around by the central black hole's gravitational field. Twin quasars are already known but turned out to be the result of "small" (means: a massive galaxy in our line of sight to them) gravitational lens effects. In these cases their seeming positions differed by some arc seconds or minutes. A number of twin quasars with significant (several degrees) angular position differences or even at opposite sites of the universe would be a proof for the above model
