I go straight up and stay stationary at a particular point (at a point above action of gravity) in the sky. The earth will rotate and I decide to drop down when my destination has come exactly below me. I would like to know why this is not possible and would like scientific justification.
Assuming you can stay stationary, you will move 180 degrees in longitude. Unless you started at the equator, you won't be at the opposite side of the world. For example, if you start at San Francisco, CA (37.788 N, 122.466 W) You would be at 37.788N, 57.534E, in Northern Iran near Turkmenistan.
Why can't you stay stationary? You need somehow to overcome gravity. If you use a helicopter or balloon, you will stay stationary relative to the air and rotate essentially with the earth. You won't be able to let the earth rotate below you. You also have to say stationary in what reference frame. You need to be stationary relative to a frame based on the center of the earth that is oriented relative to the stars. Otherwise the earth's orbital motion will cause you trouble.
- 8,663
You can not become stationary. what ever you do, you are moving with the earth as it rotates.
(I think no more explanation is needed.)
- 554
- 2
- 11
Yes, it would work. The trouble is becoming stationary. The earth is moving, and the trees, sky, and even you are moving with it.
- 4,019
