I heard that anti-particles annihilate when in contact with normal-particles but the odd thing is that in fusion reaction normal-particles often "fuse" into each other but the weak force often prevents it from happening so my question is how can anti-particles annihilate with each other for anti-particles from what I know (not much!) are affected by gravity as they fall downwards like like expected and their electrically behave same in sense that they attract with opposites and repel with other particles with same charge.
Now logic follows weak-force must also act as expected however clearly it annihilates so what force dictates that, I personally do not think it is the electrical forces as they are far from as strong as the weak force so what dictates this annihilation?
Is there a force? Is there a quantum effect? or what is it?
If your question is how can antiparticles get close enough to annihilate, they are always oppositely charged (electron/positron, proton/antiproton, etc.) or both neutral (neutrino/antineutrino, neutron/antineutron, etc.) so there is at least no repulsion and maybe electrostatic attraction. This is in contrast to normal matter fusing, where all the nuclei are positively charged and repel one another.
The force involved in annihilation is normally either the color force (in the case of quarks/antiquarks) or the electromagnetic force (in the cases of electrons/positrons).
-1
Whatsoever properties of matter or antimatter are related to "charge" at particle level.........are responsible for annihilation phenomena .Now an interesting question could be that if so then how is it possible that two particles neutron and its anti-particle can annihilate each other...? The reason for this is the , fact of composite nature of neutron and anti neutron.
