14
I am doing my final year engineering project on Magnetic Field Assisted Combustion and was curious to see what people thought about it.
Companies sell rare earth magnetic arrangements to be attached to fuel lines of gas burners and they are said to improve combustion efficiency but why exactly?
I have performed a number of experiments using a standard butane/propane gas burner with some magnets manufactured by one of said companies and have had some contradicting results. With lower strength magnets, heat transfer unexpectedly slowed down but with a much stronger arrangement, heat transfer rate was increased.
Also, the burn out time of the same amount of gas took 8 minutes less with the magnets in place around the fuel line.
I have read a number of journals on similar subjects but even within these, the actual reason for the increase in heat output is still not known.
Any thoughts on the subject would be massively appreciated and possibly give me some other areas to investigate that I have not already thought of.
James Dawson
  • 141
The Zeeman effect describes the interaction between the magnetic field and atoms. It lowers or rises the energy level of each atomic state, in your case molecular state. It`s impossible to ionize a gas with magnetic field, since this would mean that that the magnetic field had done work to the system. My guess is that the magnetic field had lowered the ionization potential.
I don't know about ionizing gas but I do know about magnetophoresis. Oxygen is paramagnetic so oxygen concentrations should be higher around magnets than in ordinary air. This could make it easier for fuels to combust.
Laff70
  • 780
  • 13
Reading the original question a posible mechanism has suggested itself to me. As the gas travels along the pipe "streaming currents" can be generated by friction. This is a phenomenon in the literature where by electrostatic charge can build up on the pipe and there is a concentration of charged particles in the boundary layer. One consequence has been instances of fuel fires when Kerosene is delivered through a hose to refuel an aircraft. The combination of such a steaming current plus a magnetic field could induce forces on the fuel maybe encouraging transition and turbulence.
-2
i would say yes. magnetic field does ionize the gas. "Ionization is the process by which an atom or a molecule acquires a negative or positive charge by gaining or losing electrons". and this as a topic already. Can I produce radio waves by waving my hand? therefore the gas MOVING through a magnetic field would accumulate a charge.
