What is fire? Is it a wave or is it matter?
Where does fire come from?
Does everything burn with fire? (for example: water and some metals don't burn).
I'll let the far greater minds than me at Minute Physics give the bulk of the answer. Turns out that the way you perceive fire is the result of numerous chemical and physical processes. I'll discuss and expand on just two major ones that were mentioned in the video I linked:
Fire is a chemical reaction ,some times hot enough to turn the gas around it into plasma which you can basically think of as a hot ionized gas. You can show that fire can form plasma by putting negatively charged plate on the left of a flame and a positively charged plate on the right of the flame. It will split the flame because the plasma is ionized.
Fire is a chemical reaction which results in the release of energy in the form of light and heat.
Fire is a chemical process, usually a self-sustaining oxydation. Things "burn" at elevated temperatures. That burning (oxydation) is exothermic. A sustained fire happens when burning something produces enough heat to cause oxidation of nearby fuel to occur, thereby causing it to burn and produce more heat, which causes more fuel to burn, etc.
Most fire is actually a reaction between gasses. The heat causes a combustible gas to be released, which reacts with atmospheric oxygen, which produces more heat, which causes more combustible gas to be released, etc. A candle flame is a good example of this. The heat causes the wax to vaporize, which allows it to react with oxygen. The wick and the liquid wax on the wick and immediately below it don't actually burn. Enough of the heat from the burning immediately above the wick makes it back onto the wick to vaporize more wax.
Do you mean the flame specifically? The flames are easier to explain as they are a more concrete thing.
Flames are gases that are hot enough to emit light in the visible spectrum via thermal radiation. Some proportion of those gases are in the plasma state, but the parts that aren't ionised are also hot enough to emit light in the visible spectrum.
