With regards to Thermal Radiation, given a stable body initially at 300 Kelvin placed in isolation, after continuous Thermal Radiation will it's temperature gradually reduce to 0 kelvin asymptotically? If so, does this mean that the body is now devoid of any Thermal Energy? And does it imply that the only energy it can possibly have is (now) due to it's electronic structure?
What happens to a body, initially at 300K, kept in isolated space? Will it's temperature drop to 0k?
In practice, no. In theory, also no.
The Universe is filled with photons with an energy distribution corresponding to $2.73\,\mathrm{K}$, called the cosmic microwave background (CMB). Every $\mathrm{cm}^3$ of space holds around 400 of them, so each second one $\mathrm{cm}^2$ is hit by roughly one hundred billion of these photons. That means that if you place your "stable body" in an ever-so-isolated box, the box itself will never come below $2.73\,\mathrm{K}$, and neither will the body inside. It will asymptotically go towards thermal equilibrium at $T = 2.73\,\mathrm{K}$.
Even if you magically removed everything else in the Universe but the body$^\dagger$, $0\,\mathrm{K}$ can never be reached. The reason is that this would imply zero motion of the atoms of the body, which is forbidden by law.
In practice, it is actually possible to have temperatures lower than the 2.73 K of the CMB. When a gas expands, it cools, and if it expands faster than it can be heated by the CMB, it can temporarily reach lower temperatures. This is the case for the Boomerang Nebula, which has a temperature of 1 K. The nebula will probably be heated to the temperature of the CMB in around 10,000 years or so.
$^\dagger$Or waited billions of years for the CMB to cool.
- 10,767
It´s impossible to drop a body temperature to absolute 0K. You must notice that, at the same time the body is radiating energy from its own temperature, it is also receiving temperature from other sources (regardless the distance of the source) like distant stars.
- 246
