46
I've read that tellurium-128 has an half-life of $2.2 \times 10^{24}$ years, much bigger than the age of the universe.
So I've thought that maybe every single isotope of every single atom are radioactive, and isotopes which we call "stable" are actually unstable but their half-life are immensely big (but not infinite), like $10^{100}$ years.
Is this a possible theory or are we truly $100$% sure that stable isotopes are really eternal?
If protons decay, then what you say is true: all atomic nuclei are indeed unstable, and a so-called "stable" nucleus simply has too long a half-life for its decay to be observed.
The most tightly bound nucleus is $^{62}$Ni, with a binding energy per nucleon of 8.79 MeV [source], which is less than 1% of the mass of a nucleon. On the other hand, the decay of a proton through a process such as
$$p \to e^+ + \pi^0$$
results in the loss of most of the mass of the proton. So if the proton can decay then it's pretty clear that an atomic nucleus always has more much more mass than a hypothetical final state in which some or all of the protons have decayed. In other words, while neutrons do not decay inside "stable" atomic nuclei because of the binding energy of the nucleus, protons cannot be so protected because their decay would be much more energetically favourable (than that of a neutron to a proton).
The question of whether protons do decay is still unresolved, as far as I know.
If protons do not decay, then the $^1$H nucleus, by definition, is stable, so there is at least one stable nucleus.
Now, you might be wondering how we can establish that a nucleus is stable (assuming no proton decay). We make the assumption that energy is conserved, and it's impossible for a nucleus to be created if there isn't enough energy in the system to make up its rest mass. Given that assumption, say we have a nucleus. If we know the masses of the ground states of all nuclei with an equal or smaller number of nucleons, then we can rule out the possibility of there being a state that the given nucleus can transform into with less total mass. That in turn guarantees that the given nucleus is stable, since it can't decay into a final state with greater mass without violating conservation of energy. For a simple example, consider a deuteron, $^2$H. Its minimal possible decay products would be:
  1. a proton plus a neutron;
  2. two protons (plus an electron and an electron antineutrino)
  3. two neutrons (plus a positron and an electron neutrino)
  4. a diproton (plus an electron and an electron antineutrino)
  5. a dineutron (plus a positron and an electron neutrino)
But all of those states have higher mass than the deuteron, so the deuteron is stable; it has no decay channel.
Of course, you might wonder whether there are possible daughter nuclei whose masses we don't know because we've never observed them. Could, say, the "stable" $^{32}$S decay into $^{16}$P (with 15 protons and 1 neutron) and $^{16}$H (with 1 proton and 15 neutrons)? After all, we don't know the masses of these hypothetical nuclei. But if nuclei so far away from the drip line actually have masses low enough for that to happen, then there would have to be some radically new, unknown nuclear physics that would allow this to happen. Within anything remotely similar to existing models, this simply isn't possible.
Brian Bi
  • 6,885
25
We are never 100% certain of anything. The scientific method falsifies wrong theories, but it does not verify those we colloquially call "correct" or "true"
If we tomorrow detect a normal oxygen atom decaying, we'll have to devise new theories to explain it.
But we don't expect the things we call stable to ever decay (that's why they're called stable). We have never seen them decay, and we - within the theories we currently accept as true - see no way how they could decay. Since those theories have done well by us in other cases, there is no reason to not trust them in this case (until evidence comes in that they are indeed false).
As a side note, Tellurium-128 is simply the nuclide with the longest half-life we have ever observed decaying. There are others, thought to be unstable with much longer half-lives, which are "observationally stable" in the sense that we've never observed them in sufficient quantity and duration to see them decay.
ACuriousMind
  • 132,081
10
In regards to a single element, this has actually happened.
Natural Bismut is about 100% 209Bi, which shows no obvious indication of being radioactive.
But it turned out that all existing bismuth is radioactive.
The isotope 209 had been suspected to be unstable before, but that was experimentally verified as recently as 2003, finding a half life of 1.9×1019 y (Note that this is significantly longer than the age of the known universe). All other isotopes are unstable, too.
As the half life is very long - meaning that relatively very few atoms decay per time, bismuth is still stable for all practical purposes.
For example, I am not afraid of the 200 g bismuth I am holding in my left hand.
Strictly speaking, no.
The hydrogen nucleus contains only one proton, there is nothing there to decay, except for the proton itself, and we do not know whether protons decay at all.
Even if we knew that any other isotope of any elements could decay, it would not change to know whether all isotopes can decay.
