I am trying to understand how the width of a supernova light curve depends on the redshift of its component frequencies.
Let us make the simple assumption that the light curve is Gaussian. The inverse Fourier transform of a Gaussian is given by:
$$\large e^{-\alpha t^2}=\int_{-\infty}^{\infty}\sqrt{\frac{\pi}{\alpha}}e^{-\frac{(\pi f)^2}{\alpha}}e^{2\pi ift}\ df$$
Now if all the components of the light curve are redshifted by a factor $k$ then I think the right-hand side of the above equation becomes:
$$\large \int_{-\infty}^{\infty}\sqrt{\frac{\pi}{\alpha}}e^{-\frac{(\pi f)^2}{\alpha}}e^{2\pi ikft}\ df$$
I now change variables in the integral using:
$$f'=kf$$ $$df'=k\ df$$
The above integral becomes the inverse Fourier transform of a modified Gaussian curve:
$$\large \int_{-\infty}^{\infty}\sqrt{\frac{\pi}{\alpha k^2}}e^{-\frac{(\pi f')^2}{\alpha k^2}}e^{2\pi if't}\ df'$$
Thus it seems that if the components are redshifted by a factor $k$ the light curve transforms in the following way:
$$\large e^{-\alpha t^2} \rightarrow e^{-\alpha k^2t^2}$$
Is this correct?
PS I now accept that the above calculation is correct and shows that redshift has the same effect as time dilation.
The width of a SN light curve is changed due to a time dilation between the source and the observer. If the source emits light with wavelength $\lambda_\text{em}$, it will be observed with wavelength $\lambda_\text{ob}$, so that its redshift is $$ 1 + z = \frac{\lambda_\text{ob}}{\lambda_\text{em}}. $$ We can also write everything in terms of frequencies $\nu_\text{em}=c/\lambda_\text{em}$ and $\nu_\text{ob}=c/\lambda_\text{ob}$:
$$ 1 + z = \frac{\nu_\text{em}}{\nu_\text{ob}}. $$ Now, suppose that the source emits $N = \nu_\text{em}\,\delta t_\text{em}$ oscillations in a time interval $\delta t_\text{em}$, then these same oscillations will be observed in a time interval $\delta t_\text{ob}$, such that $N = \nu_\text{em}\,\delta t_\text{em} = \nu_\text{ob}\,\delta t_\text{ob}$. Therefore $$ 1 + z = \frac{\delta t_\text{ob}}{\delta t_\text{em}}. $$ In other words, any time interval $\delta t_\text{em}$ is dilated into $\delta t_\text{ob}$.
Pulsar
  • 14,970
