11
This may seem like a silly question, but I believe this to be very fundamental because the Standard Model of particle physics seems based on the axiom or assumption that neutrons and protons exist “as-is” inside atomic nuclei.
Why else would the standard model require a strong nuclear force to hold everything together?
Surely there must be more evidence that this is the case besides the fact that neutrons and protons appear when a nucleus is smashed ?
EDIT: It has been a long time since I asked this question, and looking at it now (dec 5 2017) it seems like I have not mentioned an important reason for asking this question. In any case, this is what I want to add to the question now:
Take for example the Helium nucleus which is postulated to consist four separate baryons that need to be kept together with the strong force in the standard model. I would expect that in that case the total mass of a Helium nucleus would be at least that of the 4 individual baryons added together, and then I would expect to have to add more mass because of binding energy of the strong force.
Instead, the mass of the Helium nucleus is less than the four individual baryons combined. Isn’t that evidence that the Helium nucleus cannot consist of four separate “as-is” baryons?
And if that is the case, what is the evidence that these, what I would call “reduced”, baryons still require a strong force to be kept together? I mean, these baryons have lost some mass in the process of fusing together in a Helium nucleus which means they have changed somehow. Then I wonder, what if this change also changes the repulsive forces between them into attractive forces for example while retaining all the other particle specific characteristics? Would that not be a more elegant explanation than a strong nuclear force?
I mean, it would not change a thing in the released energy levels when fusing two protons and two neutrons together. The only thing that changes is the model. A model that seems just as compatible with the data as the model with a strong nuclear force.
Evidence that there are distinct protons and neutrons in nuclei starts with the Pauli term (pairing term) in the semiempirical mass formula of the liquid drop model.
Furthermore, all nuclei with even numbers of protons and neutrons have nuclear spin of zero. This is consisent with shells being filled with spin up and spin down pairs of nucleons, each pair resulting in net zero spin.
More generally, that experimental data are consistent with the Nuclear Shell Model is evidence that distinct protons and neutrons exist in the nucleus.
Also, the protons and neutrons are held together by exchange of pions. The exchange can result in the proton becoming a neutron and a neutron becoming a proton, so it is not that they exist entirely "as is".
See A reappraisal of the mechanism of pion exchange and its implications for the teaching of particle physics for furthur discussion of pion exchange.
DavePhD
  • 16,314
Short answer: We can measure their energy and momentum distribution functions in the nucleus.
We do this by interacting with them individually, either knocking them out of a nucleus left otherwise undisturbed (quasi-elastic scattering) or by exciting them to higher energy states inside the nucleus (many inelastic scattering reaction backed up by data from various capture and production reactions).
Quasi-elastic Scattering
The quasi-elastic scattering route is a reaction I know well because I did my dissertation work on Color Transparency using $A(e,e'p)$ as the probe. A well characterized electron beam is scattered from a fixed, nuclear target and the products measured with two spectrometers positioned and tuned to detect the scattered electron and proton in elastic kinematics (i.e. as if the target had been $^1\mathrm{H}$ rather than a nucleus) to within Fermi-momentum. The only thing that is difficult about the measurement is how small the cross-section gets as the squared momentum transfer $Q^2$ grows.
The measurement gives us a picture of the energy and momentum distribution of the protons inside the nucleus, and for small $A$ these results are quite consistent with results of mean-field computations (which agree with the abstract shell-model for nuclear structure). For larger $A$ they remain qualitatively consistent but the precision of agreement drops a bit.
I want to emphasize that though the reaction here is a knock-out reaction, the thing we're measuring is the energy and momentum that the knocked out nucleon had inside the nucleus.
Excitation
By measuring the energies of the gamma rays released by excited nuclei and the momentum transfer to particles used to excite them we get another probe of the internal structure of the nuclei and this probe is likewise consistent with the shell model. A data set I've done some reading about here concerns the energy levels of $^{17}\mathrm{O}$, which can be probed in situ, by various inelastic collisions and by creation of short-lived, highly excited states in the reaction $^{13}\mathrm{C}(\alpha,n)^{16}\mathrm{O}$.
Here we are measuring the difference in energies between different states occupied by single nucleons. Again, the energy the nucleon had in the nucleus.
