Suppose you are faced with a zombie, and the only way to kill it and save yourself is to chop its head off with your sword. However, you are very weak from illness, and can only afford to strike once.
Question:
To ensure that you cut in a single blow, should you hit with the tip of your sword, or should you hit near the base?
Reasoning:
  • Tip: As the sword is moving in an arc, the tip has a faster linear speed compared to the base. P = MV, and so the tip of the sword has more momentum, and thus will be able to exert more of a force on the zombie's head, cutting it.
  • Base: The zombies head requires a force of x to break. if you position it near the base, it has less leverage as it is close to the pivot (you/ your waist) and so requires less force to break through.
Which is it, and why?
Deep
  • 393
TL;DR:
If you have to choose either "near the handle" or "near the tip", the tip will work better. But there's a point in between these two that works even better; exactly where that point is depends on how you swing the sword, and how its weight is distributed.
UPDATED now I am near a computer and can draw diagrams etc.
If cutting off the zombie's head is an inelastic collision that requires the greatest transfer of momentum/energy, then clearly this will be achieved if the sword stops moving completely at the end of the stroke - if the sword keeps moving it still has energy / momentum that wasn't used to chop off the head.
This is achieved when you hit at the center of percussion: the point along the sword where you would feel no "twang" when you hit (on sports equipment like bats and rackets they call it the "sweet spot").
The exact location of the center of percussion depends on the geometry of the sword. Many medieval swords had a heavy pommel - not only to make it harder for the sword to slip from your hand, but also to increase the moment of inertia and thus move the center of percussion (the center of rotation of a sword is typically not the end - if you "flick the wrist" it will be inside the sword, while a broad swing from the shoulders with straight arms might move it further back).
It is conceivable you can put the center of percussion at the tip of the sword - this happens when you swing the sword (assuming it is a uniform rod) about a point that is $\frac13$rd of the way along the length. The point can be moved by changing the weight distribution. However, if you swing from the shoulders, the tip is not the most effective place for momentum transfer.
Some more details:
First - the motion of a rod when struck. The following diagram is helpful:
If we strike any rod (length $L$) with an impulse $P$ at a distance $d$ below the center of mass, then the rod will move in such a way that the point $C$ will initially not move - in other words we get rotation about $C$. This is true regardless of the mass distribution of the rod - only the position of C will change. Conservation of angular momentum about the center of mass gives
$$Pd = I\omega\tag1$$
and for rotation about $C$ we can write
$$P(x+d) = (I+mx^2)\omega\tag2$$
It follows that
$$Px = mx^2\omega$$ $$P = mx\omega\tag3$$
Combining (1) and (3) we get
$$mxd = I$$
and we know that for a uniform rod, $I=\frac{mL^2}{12}$. Thus, when the rod is struck at the end, $d=\frac{L}{2}$ and solving for $x$ we find that the center of percussion $C$ is found at a point that is $\frac{L}{6}$ above the center of mass.
The same analysis can be used in reverse: if I rotate the rod about point $C$, then it will come to a complete stop if we hit it at a point that is $d$ from the center of mass. Now why would that give the greatest impact?
Remember that the center of mass of an object moves as though all the forces acting on the object act at the center of mass - so if we look at the motion of the center of mass before and after the impact, we can determine what the sum of external forces was. For the purpose of the analysis, I am assuming that the force of the hand on the sword during the moment of impact is small compared to the force of the swing - in other words, if I just spent a second getting my sword up to zombie-head-cutting speed, the additional force I can provide during the moment of impact is small. If you don't neglect that, the answer can change.
Here are two scenarios - hitting just above, or just below, the center of percussion:
As you can see, in either case the center of mass continues in the original direction, although with reduced speed. This shows that the total impact $P=m\Delta v$ is less than if the impact was exactly at the center of percussion (which would have resulted in no rotation after the impact).
In this drawing I put the center of rotation $C$ outside of the sword - a good swing with a broadsword capable of zombie-killing probably requires full body engagement with hips and shoulders; in that scenario the distance $x$ becomes large, and $d$ has to be smaller. The further away the point of rotation, the more you want to strike close to the center of mass - the product remaining constant. In the case of a uniform mass distribution the relationship is
$$xd = \frac{L^2}{12}$$
But regardless of the shape of the sword, when you double the distance to the point of rotation you halve the distance to the center of percussion.
There is a nice demo of various objects being sliced in slow motion with a Katana that you can see on YouTube.
A still shot from the "pork chop" slicing - which they claim is the most realistic simulation of a human - is shown here:
While you can't see the whole blade in this frame, it looks to me that the point of impact is closer to the center of the blade than to the tip - just as you would expect if you are trying to hit near the center of percussion, and the sword is rotating about a point near the hilt or beyond.
Note that the katana doesn't just "push" but, because of the angle, also "slices" - it pulls as it strikes so there is a cutting motion. But the image clearly shows that the person handling the sword chooses a point inside (not the tip) to make the cut. This agrees with the above analysis.
One final note: if you hit with a point beyond the center of percussion there is a reaction force on your hands that makes you pull back on the blade - the force is away from the direction of the strike. And if some of the deceleration of the blade is provided by the hands, the momentum imparted to the zombie is less.
If the point of impact is inside the CoP, holding the blade still would require a force in the direction of the impact, and could theoretically result in greater transfer of momentum.
However, the time of impact is very short - if you assume that you moved the blade through a 120 degree arc, and the 15 cm neck of the zombie at a distance of 1 m represents an arc of 0.15 rad $\approx$ 10 degrees, then the time during which you could apply additional force (increase momentum of the sword) is at most 10% of the time of your swing - and so a very small correction (assuming you were using all your strength to swing the blade to begin with).
A final point - when a katana is used to injure an opponent (rather than sever the head) in battle the fighter will typically use the blade at an angle and slice with just the tip (5 cm). This does not provide the greatest transfer of momentum but rather ensures that the blade will not get stuck (as the center of mass keeps moving it will counter rotate the blade and pull it out). This means that the fighter can continue the arc, keep control of the blade, and have it ready for a next blow - either to attack or defend. But here we are taking about a single death blow - so this reasoning does not hold.
Floris
  • 119,981
In order to get a clear picture consider the outcome of an impact between the head (m = 1Kg) and a blunt rod (plus arm M = 3 Kg, L = 1 m) rotating with angular velocity 1 r/s: enter image description here
If the sword hits with its tip the effective mass is 1 Kg at speed 1 m/s the head would get momentum 1 Kg*m/s
If it hits at the hilt (r = .5 m) the effective mass is the same but speed is half and consequently momentum is half, too, if it hits in between momentum changes accordingly, and momentum is what really matters
The correct answer has been given by linus since what causes more damages in an impact is momentum, but the 'soft spot' has been vaguely suggested as a better solution in a comment and in an answer and probably it is opportune to give some concrete and precise information about that issue.
The center of percussion is the point on an object where a perpendicular impact will produce translational and rotational forces which perfectly cancel each other out at some given pivot point, so that the pivot will not be moving momentarily after the impulse. The same point is called the center of oscillation for the object suspended from the pivot as a pendulum..
you can see in the diagram that in a rod (M = 8 kg L 1m) of uniform density the CoP is at 1/3 from the Center of Mass
enter image description hereenter image description here
I am quoting Wihipedia since it has been quoted in the accepted answer
The center of percussion of a sword is the point on the blade where cutting produces the least hand shock. It is also the division between the weak and middle sections of the blade... like the center of balance of a sword, the center of percussion can be moved by employing a heavier pommel or changing the mass distribution of the blade.
This explanation has been misinterpreted:
As you can clearly see in the right diagram the sword stops moving at the hilt, at the side opposite to the CoP, because the linear velocity (to the right) and the rotational velocity (to the left) have equal value and opposite direction, while the tip of the sword keeps rotating and would also move to the right in a straight line if it were not held tight.
besides that
It is possible to put the center of percussion at the tip of the sword - I believe this happens when you hold the sword at 5/12th of the way along the length.
you can easily verify that it would be practically impossible to put the CoP at the end of the sword.
It is probably opportune to conclude the explanation reminding that...
The sweet spot on a baseball bat is generally defined as the point at which the impact feels best to the batter ... Although it has long been believed the center of percussion and the sweet spot are the same, recent practical observations have indicated that the point many batters feel is "sweetest" corresponds to a pivot point in the arm, beyond the handle of the bat
The CoP and soft spot are important in baseball because even the least swing of the bat at the wrist of the batter makes a great difference in the trajectory of the ball. But there is no chance that the bat or the sword can fly off the hand.
In conclusion, hitting a head with the point of a sword (roughly)at one third from the center, at 66.6 cm from the hilt makes only the wrist of the fighter feel more comfortable: the tip of the sword behaves in the regular way (the collision is obviously always inelastic since both bodies are not elastic) and you are only subtracting precious momentum to the blow.
As I said in my comment: ".. the only advantage you have hitting at the sweet spot is that you only no backlash at the wrist, but if you have a firm grip there is no problem and the sword has more momentum. If you cannot hold your sword,... don't fight "
I do kenjutsu, and kenjutsu sparring, my physics not good but emperically. The tip of the sword. If you have strong grip. (i.e. weight transfers).
If on impact you lose all power in your wrists and hand (i.e super wus), then better in the slightly in front of centre of balance of the sword. As the sword will fly off (centripedal forces). I assume the friction will then balance out, and the full weight of sword only can then transfer into neck of zombie.
Conclusion: 1. Tip if strong hands. 2. slightly front of centre if letting go of sword on impact.
