-1
Is time just an axiom? Or can it be proven to exist?
Correct me if I'm wrong, but our whole understanding of the universe is based on directly observing the world and building out axioms that are consistent with our observations.
Unfortunately, axioms cannot be proven to be true (I believe Godel's incompleteness theorem proved that). So if time is an axiom, then it is not provable.
Time also cannot be directly observed either, unlike perceiving an object (seeing a moon, feeling the pressure of the water, etc.)
Time is also irrelevant for some physical concepts such as Work.
With all of that said, my question is can time be proven to be/exist? And a secondary question of are there physical/mathematical theories being developed that take it as their axioms that time does not exist?
Anton
  • 273
The proof is very simple. But for the answer you must ask first: what is time? And that is a bit more difficult.
In special relativity (Minkowski diagrams) we currently distinguish between the observed time and the proper time.
Observed time is only relative to each observer, but it has the advantage that we can build up a time axis, permitting to say that two events are happening simultaneously or not. But another observer moving at another relative velocity will have another perception - simultaneity is relative.
Proper time is absolute. Proper time is the time which is measured by a clock. If you feel that you are getting older it's your inner clock which is telling you so. The proper time of a thing is the same for each observer. Your twin brother coming back from a travel near light speed will be younger than you (due to the so-called twin paradox) but nevertheless he will estimate your proper age in the same way as people do who remained on Earth, and in the same way as yourself. If you are 60 and you are looking like 60 everybody will agree that you are 60 years old. It's your proper time.
The main error committed with respect to time is to think that spacetime provides the answer of what time is. Within Minkowski spacetime, time is a fourth dimension. Minkowski spacetime provides a relation between space and time. Many physical questions may be resolved by spacetime. But for the question what time is Minkowski spacetime cannot help because Minkowski spacetime is relative.
As a consequence, time is reduced to proper time, the proper time of any clock. And you will understand the physical definition of time: time is what is measured by clocks. Nothing more and nothing less. Have a look at your watch, see how time is passing. Feel yourself getting older, time is not exempting you. There is no need for additional proof that time exists.
Moonraker
  • 3,173
Check Shape Dynamics. In some sense, time doesn't exist in this formalism.
Rexcirus
  • 5,191
