10
Assuming the spacetime principle, if the space is modified the time does too. So if the velocity in the space is increase, does the time slow down? What happens if the speed is the speed of light, does the time stops?
Alejandro
  • 785
No, for several reasons.
First, the idea of time "slowing down" is a little bit of a misnomer. If you were traveling at relativistic speeds, you would not perceive the passage of time any differently than you do right now. It's only when you compare your clocks to an observer in another reference frame (let's me, sitting in my living room, at rest with respect to the ground) that you would notice that your clock shows a smaller passage of time than mine does. So within your own frame of reference, it makes no sense to talk about time ticking slow or fast, it's only when you compare your clock to a clock in another reference frame that you can compare passages in time.
Also, and this is probably the larger hang-up to your question, is that a particle with mass can never reach the speed of light. With truly astounding amounts of energy, you could get arbitrarily close to the speed of light, but never reach it. The reason is because at relativistic speeds, the equation for kinetic energy is different than the classical equation for kinetic energy that you're used to.
Classically, the kinetic energy of a moving particle is given by $$KE=\frac{1}{2}mv^2$$ where we can reach any finite velocity that we want, so long as we do enough work on the object to increase its kinetic energy to the proper amount. However, it turns out that this is equation is only an approximation for small velocities. Relativistically, the equation for kinetic energy is $$KE=\frac{mc^2}{\sqrt{1-\frac{v}{c}^2}}-mc^2$$. What this equation shows you is that for any finite amount of kinetic energy on an object $v<c$. If you have trouble seeing this, attack the equation from a different angle. Let's say I'm crazy, and it is possible to travel at the speed of light. So let's take $v=c$ and substitute that into our relativistic kinetic energy equation. Oh no! You'll see that we get a divide by zero error, because our entire denominator goes to zero. This means we would need an infinite amount of kinetic energy for our object and that's just not possible.
So I hate to burst your bubble, but no light-speed travel for you anytime soon. (Or ever).
Sean
  • 3,033
Its not possible to stop time but using relativity it can be thought of to be slowed down .
Nothing can be faster than the speed of light so its not possible .
Even when we near it , energy tends to become infinity .
stud
  • 311
Things will be bigger/smaller/slower with speed as $\frac{1}{\sqrt{1-\frac{v^2}{c^2}}}$.
Thus, as $v \rightarrow c$,
  1. Mass (or energy) goes to infinite,
  2. Time goes to zero.
But it is only a limit, which is unreachable (at least in the special relativity), because of (1).
peterh
  • 8,872
