For 2D Time-Reversal Invariant systems ($T H(\vec{k}) T^{-1} = H(-\vec{k}) $), there is a formula by Fu-Kane-Mele in order to determine whether the system belongs to either one of distinct topological phases: simple insulator or topological insulator. The formula can be found in this first paper from 2005 (see also arXiv:cond-mat/0607699) for instance.
All the formulas I have found so far to compute this $\mathbb{Z}_2$ index require that one computes the eigenstates of $H(\vec{k})$ first. Then, for example, one has to count the zeros of a certain Pfaffian of some overlap matrix of the states with the time-reversed states, or compute certain integrals of the Berry-curvature and connection over part of the BZ. But still, one has to know the eigenstates in order to proceed.
However, in order to compute the Chern number, for example, one only has to know the projectors onto the occupied states.
So my question is: suppose that all I am given is the Hamiltonian ($H(\vec{k})$, in the form of some $N\times N$ Hermitian matrix with entries which are continuous functions over the BZ) so that there is no clear way to compute eigenfunctions, is there a direct formula that gives the $\mathbb{Z}_2$ invariant index from the entries of $H(\vec{k})$? If not, is there a formula that uses only the projector onto the occupied states, $P(\vec{k})$?
Xiao-Gang Wen
  • 13,725
PPR
  • 2,234
