How do you find a metric tensor given a coordinate transformation, $(t', x', y', z') \rightarrow (t, x, y, z)$? Our textbook gives a somewhat vague example as it skips some steps making it difficult to understand. What's the general definition for a metric tensor of a given transformation? The closest I could find was http://en.wikipedia.org/wiki/Metric_tensor#Coordinate_transformations, but I'm having trouble understanding that.
A metric tensor1 does not correspond to a coordinate transformation, it corresponds to a coordinate system. The initial coordinate system, with coordinates $(t',x',y',z')$, corresponds to one metric tensor $g_{\mu\nu}'$, and the final coordinate system, with coordinates $(t,x,y,z)$, corresponds to a different metric tensor $g_{\mu\nu}$. When you transform from the primed coordinate system to the unprimed coordinate system, you also transform the metric tensor from the primed $g_{\mu\nu}'$ to the unprimed $g_{\mu\nu}$.
The rule by which you transform the metric tensor when changing from one coordinate system to another is
$$g_{\mu\nu} = \frac{\partial {x^\rho}'}{\partial x^\mu}\frac{\partial {x^\sigma}'}{\partial x^\nu}g_{\rho\sigma}'$$
If your initial (primed) coordinate system is the Cartesian system of Minkowski space, then it corresponds to a metric tensor of $\pm\operatorname{diag}(-1,1,1,1)$, and you get
$$g_{\mu\nu} = -\frac{\partial t'}{\partial x^\mu}\frac{\partial t'}{\partial x^\nu} + \frac{\partial x'}{\partial x^\mu}\frac{\partial x'}{\partial x^\nu} + \frac{\partial y'}{\partial x^\mu}\frac{\partial y'}{\partial x^\nu} + \frac{\partial z'}{\partial x^\mu}\frac{\partial z'}{\partial x^\nu}$$
In this case it may look like the metric tensor corresponds to the transformation, but that's only because you started from a particularly simple coordinate system.
1In the above post, when I say "metric tensor" I actually mean "matrix representation of the metric tensor". Technically, a tensor itself is an object which exists independent of any coordinate system, and in particular the metric tensor is a property of the underlying space. Once you choose a particular coordinate system, you can represent the tensor in that coordinate system by using a matrix. That matrix representation of the tensor is what changes as you transform from one coordinate system to another.
- 115
- 77,804
You look at the distance between two infinitesimally different points. Let the two coordinate systems be x and y, where x is four numbers and y is four numbers. Consider an infinitesimal displacement from y to y+dy. You know this distance in the x coordinates, so you find the two endpoints of the displacement
$$x(y)$$ $$x^i(y + dy) = x^i(x') + {\partial x^i \over \partial y^j} dy^j $$
This is using the Einstein summation convention--- repeated upper/lower indices are summed automatically, and an upper index in the denominator of a differential expression becomes a lower index, and vice-versa. The distance between these two infinitesimally separated points is:
$$ g_{ij}(x) {\partial x^i \over \partial y^k} {\partial x^j \over \partial y^l} dy^k dy^l $$
And from this, you read off the metric tensor coefficients--- since this is the quadratic expression for the distance between y and y+dy.
$$ g'_{kl}(y) = g_{ij}(x(y)) {\partial x^i \over \partial y^k} {\partial x^j \over \partial y^l}$$
This is a special case of the tensor transformation law--- every lower index transforms by getting contracted with a Jacobian inverse, and every upper index by getting contracted with a Jacobian.
- 13,064
