I feel I am missing something about deriving Maxwell relations. I have read http://ocw.mit.edu/courses/physics/8-044-statistical-physics-i-spring-2013/readings-notes-slides/MIT8_044S13_notes.Max.pdf and as far as I can see if we have $dE=TdS+FdL$, the only maxwell relation will be
$$\frac{\partial F}{\partial S}=\frac{\partial T}{\partial L} $$
So how is the given maxwell relation in the picture found?
Trajan
  • 895
As you said, the relation you have is $$ dE = TdS + FdL $$ So one maxwell relation is $$ \left(\frac{\partial T}{\partial L}\right)_S = \left(\frac{\partial F}{\partial S}\right)_L $$ Which is the one you have obtained. For get the other do the following transformation $$ dE = TdS + FdL = d(ST) - SdT + FdL $$ $$ \implies d(E-ST) = -SdT + FdL $$ Since $-SdT + FdL$ is an exact differential, the cross derivatives coincides, so you can read the other maxwell relation $$ -\left(\frac{\partial S}{\partial L} \right)_T = \left(\frac{\partial F}{\partial T} \right)_L $$ Which is the one on your textbook.
Héctor
  • 933
Specifically the result you have is $$\left(\frac{\partial F}{\partial S}\right)_L=\left(\frac{\partial T}{\partial L}\right)_S$$
So using the cyclic rule for partial derivatives we can write that $$ \left(\frac{\partial T}{\partial L}\right)_S=-\left(\frac{\partial T}{\partial S}\right)_L \left(\frac{\partial S}{\partial L}\right)_T$$
So if we sub this in and multiply both sides by $\left(\frac{\partial S}{\partial T}\right)_L$ we have $$\left(\frac{\partial F}{\partial S}\right)_L \left(\frac{\partial S}{\partial T}\right)_L=-\left(\frac{\partial T}{\partial S}\right)_L \left(\frac{\partial S}{\partial T}\right)_L \left(\frac{\partial S}{\partial L}\right)_T$$
and since $$\left(\frac{\partial F}{\partial S}\right)_L \left(\frac{\partial S}{\partial T}\right)_L=\left(\frac{\partial F}{\partial T}\right)_L$$ and $$\left(\frac{\partial T}{\partial S}\right)_L \left(\frac{\partial S}{\partial T}\right)_L=1$$
you get the required result
$$\left(\frac{\partial F}{\partial T}\right)_L=-\left(\frac{\partial S}{\partial L}\right)_T$$
ChrisM
  • 1,800
  • 17
  • 27
