I want to understand how bracket operations in general are related to symmetry and infinitesimal transformations (in hindsight of quantumfieldtheory), so I calculated an example with a particle that is moving on a circle with a generic potential. (I used simple polar coordinates in two dimensions)
$H(r,p_{r})= \frac{p^{2}_{r}}{2m}+V(r)$
$H(\phi, p_{\phi})=\frac{p^{2}_{\phi}}{2mr^{2}}+V(\phi)$
Now I know that if you take the Poisson bracket with the Hamiltonian you just get the infinitesimal transformation in time right? So
$\{r,H(r,p_{r})\}= \frac{p_{r}}{m}$
$\{\phi,H(\phi,p_{\phi})\}= \frac{p_{\phi}}{mr^{2}}$
But what if I want to do an infinitesimal transformation of the $r$ or the $\phi$ coordinates? I know that the generator of translations is just the momentum, and that the generator of rotations is angular momentum. How would I do that with the Poisson bracket in this case? And for example when I do an infinitesimal transformation with the radius $r$, what does that mean? Is it that the radius is infinitesimally transformed, or is it more like a global translation where the whole system is somehow translated? Similarly with the angle $\phi$, is it that the angle is locally changed, or is it that the "whole" system is rotated?
Suppose $g$ is the generator of a certain symmetry (i.e. the generating function of an infinitesimal canonical transformation) and you are interested to know how the observable $f$ changes after the "action" of $g$. In the Hamiltonian formalism the change is found to be $$\delta f \approx \epsilon\{f,g\}$$ which can be related to the time evolution of an observable, where the generator is the Hamiltonian itself, since $$\delta f \approx\{f, H\}\delta t.$$ If you now replace the Hamiltonian $H$ with the momentum $p_r$, the above becomes $$\delta r = \epsilon\{r,p_r\} = \epsilon\cdot1,$$ and this shows that $p_r$ is translating along the radial coordinate, while it is doing nothing on the angular variable, since $$\delta\phi = \epsilon\{\phi,p_r\} = \epsilon\cdot 0.$$
Phoenix87
  • 9,759
