-2
How can we prove the explanations for: why clothes get dark when they are wet, by experiments?
fahim
If "wet" causes the material to become less scattering, and thus darker, because of a smaller change in refractive index between the fibers and the liquid, then the experiment to do would be to change the refractive index of the liquid. If you can see a change in "darkness" as a function of refractive index (making sure to correct for surface reflection effects) this supports the explanation - you could also look for a change in the "lightness" in transmission, as Georg pointed out (and as I mentioned in this earlier answer. However, as ACuriousMind pointed out - you can't prove that it is the right explanation. You can only ever say "I still haven't disproved it".
Floris
  • 119,981
