I got to solve a simple exercise about special relativity when I kinda came to the conclusion it doesn't stroke with my intuition.
The homework-problem
The problem was about two people Sam and Leyla in a reference frame $S'$ that moves to the right relative to another reference frame $S$ at rest with a speed of $0.6c$ ($c = $ lightspeed). Now another person Adam looks from reference frame $S$ to Sam and Layla who are standing $1.8 \cdot 10^{12}$m apart and throwing a ball (Leyla throws to Sam) at a speed of $0.8c$ in the opposite direction of the movement of the reference frame $S'$ they're in (so actually $-0.8c$).
I already calculated several things. So I know the distance for Adam in reference frame $S$ is $1.44 \cdot 10^{12}$m and the speed of the ball is $0.385c$. Both time dilatation and Lorentz transformations got involved for these calculations.
The question that's causing the real trouble
Now I have to calculate the time needed for the ball to reach Sam (who is standing left to catch the ball) in the eyes of Adam.
I kind of thought the time difference could be calculated with time dilation, knowing that the time difference in $S'$ is $7500$s, but this doesn't lead to the correct solution (result was 9,375s). I also tried calculating the time difference with the fact that I know the speed of the ball and the distance relative to Adam, but this doesn't give the correct result either (result was 12,468s) and this is where my intuition breaks because this means the ball seems to need less time to reach Sam than the time it needs to cross $1.44 \cdot 10^{12}$m if it has a speed of $0.385c$.
The correct answer should be 4,875s and can be calculated with Lorentz-transformations.
My specific question
Why should this be the only correct answer and what are the mistakes in my reasonings, please?
