Why do planets revolving around the Sun not stop revolving? Note I am not asking why planets do not collapse with Sun.
The angular momentum of any particular planet around the Sun (or the angular momentum of the planet-Sun system around its center of mass) is huge. To change the angular momentum of a system requires a torque exerted over some time interval: $$\frac{dL}{dt}=\tau \hspace{1in} \Delta{L}=\int \tau dt $$
There are simply no torques large enough to change the angular momentum appreciably in time frames meeting human existence. Even planet-to-planet gravitational interactions don't create appreciable torques as far as revolution around the Sun is concerned.
The Sun (ideally as a spherical, radially distributed mass) exerts no torque on a planet about any point along their adjoining line.
On the other hand, the existence of Neptune was inferred by wobbles in the motion of Uranus due to their mutual gravitational interaction.
There are apparently some very small torques within the solar system which result in the precession of rotational axes, but nothing large enough to cause revolution to change.
- 15,522
