Consider an observer $A$ moving in a spaceship at a speed close to $c$, relative to an observer $B$. The $B$ knows that the time on $A$ runs slower, but in the inertial frame of $A$, $B$ is moving away at the same speed close to $c$, while $A$ is stationary. Would $A$ think the time in $B$ is slower?
George
  • 199
Absolutely YES!the term "relative to..." tells you everything!
Alright.
Moreover, since the motion of $A$ with respect to $B$ is supposed to be characterized by some particular "speed" (even if it were not constant) therefore we may assume that $B$ is a member of an inertial system; namely having been and having remained at rest with respect to suitable additional participants (say observers $K$, $Q$ ...), where, let's say, $A$ moved from $B$ to $K$, then on to $Q$, etc.
In the following let's suppose that the "speed" which the members of $B$'s ($K$'s, $Q$'s) inertial system measure of $A$ is a constant: $v_B[~A~]$ which is necessarily smaller than $c$ (the "signal front speed", a.k.a. "speed of light in vacuum"), even though it may be close to $c$.
That seems a nonsense assertion
("time on $A$ running slower" than what ??, by which method of comparison ??).
Correct is instead that the comparison of durations between $A$ and $B$ can (and, by the setup prescription above typically does) involve the "Lorentz factor" $$\sqrt{ 1 - \left( \frac{v_B[~A~]}{c}\right)^2 },$$
a.k.a. "$1/gamma$", whose value is necessarily less than 1. Specificly:
$$ \tau A_{\circ B}^{\circ K} = \sqrt{ 1 - \left( \frac{v_B[~A~]}{c}\right)^2 } ~\times~ \tau B_{\circ A}^{\circledS K \circ A},$$
where
  • "$A_{\circ B}$" denotes participant $A$'s indication of having been met and passed by participant $B$,
  • "$A^{\circ K}$" denotes participant $A$'s indication of having been met and passed by participant $K$, and thus
  • "$\tau A_{\circ B}^{\circ K}$" denotes $A$'s duration from having been met and passed by participant $B$ until having been met and passed by participant $K$,
  • "$B_{\circ A}$" denotes participant $B$'s indication of having been met and passed by participant $A$,
  • "$B^{\circledS K \circ A}$" denotes participant $B$'s indication simultaneous to participant $K$'s indication of having been met and passed by participant $A$, and thus
  • "$\tau B_{\circ A}^{\circledS K \circ A}$" denotes the duration of $B$ between these two of its indications.
A detailed derivation of this equation can be found here (PSE/q/110316).
Good!, that's consistent with my above assumption of speed $v_B[~A~]$ being constant. So, being a member of an inertial frame, $A$ is also at rest with respect to suitable additional participants (say observers $J$, $P$ ...), where, let's say, $B$ moved from $A$ to $J$, then on to $P$, etc.
These participants may therefore in turn measure the speed of $B$ (with respect to their, $A$'s, inertial frame): $v_A[~B~]$;
and necessarily it would be found that
$$v_A[~B~] = v_B[~A~],$$
thus both (mutual) speed values being constant.
Right.
Surely, $A$ would not think such nonsense, either;
but, correspondingly to the measurements by $B$ along with $K$ etc., further comparisons between $A$ and $B$ of their durations can be obtained as
$$ \tau B_{\circ A}^{\circ J} = \sqrt{ 1 - \left( \frac{v_A[~B~]}{c}\right)^2 } ~\times~ \tau A_{\circ B}^{\circledS J \circ B},$$
where
  • "$B_{\circ A}$" denotes participant $B$'s indication of having been met and passed by participant $A$ (as had been mentioned above already),
  • "$B^{\circ J}$" denotes participant $B$'s indication of having been met and passed by participant $J$, and thus
  • "$\tau B_{\circ A}^{\circ J}$" denotes $B$'s duration from having been met and passed by participant $A$ until having been met and passed by participant $J$,
  • "$A_{\circ B}$" denotes participant $A$'s indication of having been met and passed by participant $B$ (as had been mentioned above already),
  • "$A^{\circledS J \circ B}$" denotes participant $A$'s indication simultaneous to participant $J$'s indication of having been met and passed by participant $B$, and thus
  • "$\tau A_{\circ B}^{\circledS J \circ B}$" denotes the duration of $A$ between these two of its indications.
user12262
  • 4,360
