As I understand it, the Euler-Lagrange equation is a necessary but not a sufficient condition to determine if the action integral reaches an extremal through the trajectory described by $q(t)$.
If this is so, what is a sufficient condition?
Let me begin with an analogy to high school calculus. We know that a function $f(x)$ has a stationary point $x_0$ if at that point $$\left.\frac{df}{dx}\right|_{x_0}=0$$ There are three possibilities: minimum, maximum and saddle. This is called the first derivative test. To test for these conditions, we use the second derivative test. We check $$\left.\frac{d^2f}{dx^2}\right|_{x_0}$$ If this is positive, $f$ is concave up and thus $x_0$ is a minimum. If it is negative, $x_0$ is concave down and a maximum. If both first and second derivatives are zero at $x_0$, it is a point of inflection, more specifically, a saddle point (a point of inflection which has zero first derivative is a saddle).
Now we come to variational calculus. Path integral quantum mechanics tells us that the action $$S[q]=\int L\,dt$$ is stationary along the classical path, a condition which we write as $$\delta S[q][h]=0$$ where the functional derivative of a functional $G[f]$ is defined as $$\delta G[f][h]=\left.\frac{d}{d\epsilon}G[f+\epsilon h]\right|_{\epsilon=0}$$ The action principle implies the Euler-Lagrange equations $$\frac{\partial L}{\partial q}-\frac{d}{dt}\frac{\partial L}{\partial\dot q}=0$$ But these equations are only necessary for extremal solutions, and saddle point solutions are possible.
So suppose we solve the EL equations and are not sure if it is a minimum, maximum or saddle point. We perform the second derivative test for functionals as follows: The second functional derivative is $$\delta^2 G[f][h]=\left.\frac{d^2}{d\epsilon^2}G[f+\epsilon h]\right|_{\epsilon=0}$$ so we look at the integral $$\delta^2 S[q_\text{c}][h]$$ where $q_\text{c}$ is the curve which solves the EL equations. If it is positive, $q_\text{c}$ is a minimum, etc.
You should take a look at this paper, "When action is not least". It discusses the differences between minima, maxima and saddle points in great detail.
Ryan Unger
  • 9,011
