An explanation of special relativity I'm struggling with, goes like this:
A rod traveling by a "stationary" observer has its length measured by use of two stationary synchronized clocks (synchronized from the perspective of the observer). The resulting length will appear "shorter" than if the rod were stationary and measured more conventionally.
I don't even understand the premise. How would two stationary clocks be used to measure the length of a moving rod? Instead I can imagine using a single clock with a "split" metric. That is, capture time when the head of the rod passes the clock, and capture the time when the tail of the rod passes. If the velocity is known, the length can be determined.
But my formulation only requires one clock, and isn't pertinent to the point of the original presentation. Can someone explain to me how two stationary "synchronized" clocks can be used to measure the length of a rod in motion?
