In this question I asked about gravity and in the answers it came up that the magnitude is equal (of the gravity acting on the Sun and the of the gravity acting on the Earth)
Does magnitude simply mean it's strength?
Jonathan.
  • 7,057
Sure - a force has a magnitude (amount) and direction (vector).
Herb
  • 301
A force is a normal vector and a vector is characterized by its magnitude ( its norm, "lenght" in graphical representation ) and direction.
Cedric H.
  • 4,856
In the case of centripetal forces, like gravity, force is always directed towards the center of mass - it's a radial force. We can therefore study most of its properties by calculating its strength.
In particular, with gravity it is typical to use polar coordinates (e.g., in 2D, use angle and radius instead of $x$ and $y$). This leads to a gravitational force which only has a radial component. In this particular case the magnitude of the force vector is the same as the radial component, so it's really easy to calculate.
In the general case, the magnitude is the length of the force vector calculated by the square root of the dot product of the vector by itself. In classical coordinates $(x,y)$
$|F| = \sqrt{(F_x^2 + F_y^2)}$
where $F_x$ and $F_y$ are the $x$ and $y$ components of the force vector ${\bf F}$.
Sklivvz
  • 13,829
