TL;DR: If the race is made interesting, it's the feather that hits first. Otherwise, it's the mountain.
Simplifying assumptions:
I'll make some spherical cow simplifying assumptions. Specifically, the Earth, the mountain, and the feather are spheres. The spherical mountain, being made of typical rock, has a density of $\frac {1125}{128\pi}\,\text{g/cm}^3\approx 2.8\, \text{g/cm}^3$. This nicely makes the spherical mountain have a radius of 8 km. The feather, being made of ultralight feather stuff, has a density of $\frac 9 {16\pi}\,\text{g/cm}^3\approx 0.18 \,\text{g/cm}^3$. This nicely makes the spherical feather have a radius of 2 cm.
The other assumption is the meaning of "both objects released at a height of 10,000 m." I see three possible interpretations of height: measured from the surface of the Earth to the top of the object, from the surface of the Earth to the center of the object, or from the surface of the Earth to the bottom of the object.
The first interpretation (height is measured from the surface of the Earth to the top of the object) doesn't make any sense given the circumstances. If the top of the mountain is 10 km above the Earth, the bottom of the mountain is 6 km below the surface. There is no race; the mountain has already won.
The second interpretation (height is measured from the surface of the Earth to the center of the object) also doesn't make much sense given the circumstances. If the center of the mountain is ten km above the Earth, the mountain only has to fall two km before it hits the Earth. The feather on the other hand has to two centimeters shy of ten km. This gives the mountain an eight kilometer advantage. This isn't even close to an interesting race; the mountain falls two kilometers the Earth in less than half the time it takes the feather to fall nearly ten kilometers.
The third interpretation (height is measured from the surface of the Earth to the bottom of the object) is the only one that makes for an interesting race. At the start, the feather's center of mass is 10.00002 km above the surface of the Earth while the mountain's center of mass is 18 km above the surface of the Earth. This means the feather's acceleration due to Earth gravity is slightly more than that of the mountain. This gives the feather a slight advantage over the mountain.
To make this a one dimensional problem, we'll drill a 4 cm deep, 4 cm diameter cylindrical hole in the mountain. The spherical feather will just fit in this hole. I'll ignore that this hole makes the mountain not quite spherical.
Who wins?
Now let's consider two races. In the first, we'll place the feather in that little pocket in the mountain, orient the mountain so the pocket faces downward, and release the spherical mountain and spherical feather simultaneously. The winner is the object that first reaches the surface of the Earth. In the second, we'll release the spherical mountain and spherical feather separately and time the separate falls. The winner is the object that takes the lesser amount of time to reach the surface of the Earth.
In the first race, the feather accelerates downward toward the Earth and upward toward the mountain. The mountain accelerates downward toward the Earth and downward toward the feather. The Earth as a whole accelerates upward toward both the mountain and the feather. Denoting $h_f$ as the height in kilometers of the bottom of the spherical feather above the surface of the Earth, $h_m$ as the height in kilometers of the bottom of the spherical mountain above the surface of the Earth, $x$ as the position in kilometers of the center of the Earth relative to it's initial position, $r$ as the radius of the Earth in kilometers, and $g=GM/r^2$ as Earth surface gravity, the differential equations that govern the first race are
$$\begin{aligned}
\ddot h_f &= -g\left( \left( \frac r {r - x + h_f + 0.00002} \right)^2 - 10^{-9} \left( \frac r {h_m - h_f + 7.99998} \right)^2 \right) \\
\ddot h_m &= -g\left( \left( \frac r {r - x + h_m + 8} \right)^2 + 10^{-27} \left( \frac r {h_m - h_f + 7.99998} \right)^2 \right) \\
\ddot x &= g\left( \left( 10^{-9} \frac r {r - x + h_m + 8} \right)^2 + 10^{-27} \left( \frac r {r - x + h_f + 0.00002} \right)^2 \right)
\end{aligned}$$
Integrating numerically, the feather wins by about 0.042 seconds. The qualitative explanation is that the slight upward acceleration of the feather toward the mountain does not make up for the greater downward acceleration the feather experiences toward the Earth compared to that of the mountain. The acceleration of the Earth as a whole toward the mountain and the feather is irrelevant in this race.
What about the second race? In this case, the acceleration of the Earth as a whole toward the mountain might well be relevant. The acceleration of the Earth as a whole toward the feather is still irrelevant because the feather's mass is so tiny. It turns out that there is essentially no difference in timing. The feather has to fall an extra 10 micrometers than does the mountain. The feather still wins by 42 hundredths of a second.
What if we use point masses?
In this case, the first race is a tie, but the mountain wins the second race.
