Suppose a boy is trying to stand on a table. If the table can hold upto a particular force, the boy would fall on to earth. If he stands on the table and providing greater force than the table can yield.
Does the table give a reaction force to the boy by newton's third law?
If so, why did he fall down ?
Vinayak
  • 926
the boy was applying a force on the table and table was also applying the same force on the boy.(upward) but since the table was weak hence it was broken. now there is nothing to apply force on the boy upward so simply gravity pulls him down.
EDIT:lets look at a different situation but similar situation to make things clear.
a boy is standing on a elevator and thus he applies a force on the floor of the elevator and the floor is also applying the same force on the boy upward. suddenly the cable broke (this is similar as the breaking of the table) what will happen? the elevator and the boy will now in freefall . In this case because both the boy and the lift are moving downwards with same acceleration 'g' so there are no forces of action and reaction between the boy and the lift. http://hyperphysics.phy-astr.gsu.edu/hbase/elev.html similar happen in the case of boy and the table.
Paul
  • 3,475
-1
Analogous to "slope with an angle $\theta$ & a box having mass $M$". When the boy is falling down, the table becomes like a slope and only on the slope surface where the third law works i.e $N=Mg cosθ$, N being the normal force exerted by the slope, rather than $Mg=N$.
