-4
We all know Newton's third law.
But then why this law doesn't work when we place a 1000KG heavy container on a small weak table. The table will break. Pressure is exerted on table by container, and table exerts force on the ground.
Similarly a heavy pillar will break a weak wall while leaning upon it.
You're confusing Newton's 1st and 3rd laws.
Newton's 3rd law pair to the weight of the mass (ie the force of the Earth on the mass) is the force of the mass on the Earth. The 1st law pair would be the contact force of the table on the weight and the force of gravity on the weight. As the table is unable to provide a large enough force to prevent the weight from falling, Newton's 2nd law applies.
I guess you are asking this: Why is the third law correct if the container makes to the table a force of 1000 kg but the table reacts with a smaller force? The error is that 1000 kg is the weight of the container, not the force it will do to the table. If the table doesn’t break, when they are at rest, it will make a force of 1000 kg to the table and the table a force of 1000 kg back (called the normal force). But if the table doesn’t resist and breaks under a force above 10 kg, then the container will make on the table a force of 10 kg, not 1000 kg. A force is an interaction between two objects. You cannot have a "force" of 1000 kg with you and apply it onto any object you want by touching it. It doesn’t work like that.
A table or a weak wall can withstand only a certain amount of force depending on its material. If we provide more force it is going to fail or break . nothing to do with 3rd law. If the table can withstand 1000KG it will and there will be a normal force according to 3rd law. hope this helps clear things up. Or you should just read about "Failure of materials " from wiki for more info.
Gowtham
  • 391
