Suppose we have two 4-components Dirac spinors, that is two non commuting objects, $\psi$ and $\chi$. We know that:
$ \bar{\psi} \chi= - \chi \bar{\psi} $
$ \bar{\psi} = \psi^{\dagger} \gamma_0 $
$\dagger=T*$
The question is the following. What is $( \bar{\psi} \chi)^{T } $ ? For $T$ I mean taking the transpose, $\dagger$ is the adjoint, $*$ the complex conjugate.
Explicitly, is $ (\bar{\psi} \chi )^{T }=\chi^{T }\bar{\psi} ^{T } $ or $ (\bar{\psi} \chi )^{T }=- \chi^{T }\bar{\psi} ^{T } $ ?
And what can we say about $( \bar{\psi} \chi)^{\dagger} $? Is $ (\bar{\psi} \chi )^{\dagger}=\chi^{\dagger}\bar{\psi} ^{\dagger} $ or $ (\bar{\psi} \chi )^{\dagger}=- \chi^{\dagger}\bar{\psi} ^{\dagger} $ ?
Please, make the explanation clear, not only giving the correct answer.
Xenomorph
  • 3,121
Rexcirus
  • 5,191
There're a few things that should be clarified. First of all, are you talking about classical spinors?
If they are classical spinors, then they take values in Grassmann-odd numbers, and so its transpose should be
\begin{align} (\bar{\psi}\chi)^{T}&=(\psi^{\dagger}\gamma^{0}\chi)^{T} \\ &=\left[(\psi^{\ast})^{T}\gamma^{0}\chi\right]^{T} \\ &=-\bar{\psi}\chi, \end{align}
where in the last step, one has
\begin{align} \bar{\psi}\chi=(\psi^{\ast})^{T}\gamma^{0}\chi &=\sum_{i=0}^{3}\sum_{j=0}^{3}(\psi^{\ast})_{i}(\gamma^{0})_{ij}(\chi)_{j} \\ &=-\sum_{i=0}^{3}\sum_{j=0}^{3}(\chi)_{j}(\psi^{\ast})_{i}(\gamma^{0})_{ij} \\ &=-\sum_{i=0}^{3}\sum_{j=0}^{3}(\chi)_{i}(\psi^{\ast})_{j}(\gamma^{0})_{ji} \\ &=-\sum_{i=0}^{3}\sum_{j=0}^{3}(\chi)_{i}\left[(\gamma^{0})^{T}\right]_{ij}(\psi^{\ast})_{j} \\ &=-\chi^{T}(\gamma^{0})^{T}\psi^{\ast}=-\chi^{T}\bar{\psi}^{T}\equiv-(\bar{\psi}\chi)^{T}. \end{align}
Now, the problem has to do with the involution of the Grassmann algebra $\Lambda_{\infty}$. To be specific, suppose you have a bunch of anti-commuting elements $\theta_{i}$, i.e. $$\theta_{i}\theta_{j}+\theta_{j}\theta_{i}=0.$$ Then, each element (also known as the supernumber) in $\Lambda_{\infty}$ takes the form $$z=z_{B}+\sum_{k=1}^{\infty}\frac{1}{k!}C_{i_{1}\dots i_{k}}\,\theta_{i_{1}}\cdots\theta_{i_{k}},$$ where $z_{B}\in\mathbb{C}$ is its body part, and $C_{i_{1}\dots i_{k}}\in\mathbb{C}$ is the coefficient of its soul part. The involution (complex conjugation) $\ast$ in $\Lambda_{\infty}$ is defined as an action satisfying the following rules:
$1.\quad(\theta_{i})^{\ast}=\theta_{i}$.
$2.\quad(\alpha z)^{\ast}=\bar{\alpha}z^{\ast}$, where $\alpha\in\mathbb{C}$.
$3.\quad(z+w)^{\ast}=z^{\ast}+w^{\ast}$.
$4.\quad(zw)^{\ast}=w^{\ast}z^{\ast}$.
$5.\quad(z^{\ast})^{\ast}=z$.
Back to your question, the classical Dirac spinors should take values in the infinite dimensional $\Lambda_{\infty}$. So you would expect
\begin{align} (\bar{\psi}\chi)^{\dagger}&=\left[(\bar{\psi}\chi)^{T}\right]^{\ast}=\left[\chi^{T}\bar{\psi}^{T}\right]^{\ast} \\ &=\left(\sum_{i=0}^{3}\sum_{j=0}^{3}(\chi)_{i}\left[(\gamma^{0})^{T}\right]_{ij}(\psi^{\ast})_{j}\right)^{\ast} \\ &=\sum_{i=0}^{3}\sum_{j=0}^{3}\left[(\chi)_{i}\left[(\gamma^{0})^{T}\right]_{ij}(\psi^{\ast})_{j}\right]^{\ast} \\ &=\sum_{i=0}^{3}\sum_{j=0}^{3}(\psi)_{j}\left[(\gamma^{0})^{\dagger}\right]_{ij}(\chi^{\ast})_{i} \\ &=\sum_{i=0}^{3}\sum_{j=0}^{3}(\psi)_{j}(\gamma^{0})_{ij}(\chi^{\ast})_{i} \\ &=-\sum_{i=0}^{3}\sum_{j=0}^{3}(\chi^{\ast})_{i}(\gamma^{0})_{ij}(\psi)_{j}\equiv-\chi^{\dagger}\gamma^{0}\psi=-\bar{\chi}\psi. \end{align}
Notice that in the last step one also has $\bar{\psi}^{\dagger}=(\psi^{\dagger}\gamma^{0})^{\dagger}=\gamma^{0}\psi$, and so you should obtain
$$(\bar{\psi}\chi)^{\dagger}=-\chi^{\dagger}\bar{\psi}^{\dagger}.$$
Xenomorph
  • 3,121
-1
EDIT: The correct answer is at: https://physics.stackexchange.com/a/458455/50207
Leaving the (wrong) answer below as it can be instructive.
I've clarified my doubt. The expression
is simply the definition of trasposition (the same argument for the adjoint), independently on the nature of the objects in the parenthesis. What is subtle is that, the following is true:
$ \bar{\psi} \chi =-\chi^{T }\bar{\psi} ^{T } =-(\bar{\psi} \chi )^{T }$
The minus in the first step arise only due to the anticommuting nature of the variables.
Rexcirus
  • 5,191
