I was reading about gravitational waves and about laser based detectors. I also read this. As mentioned in the answer, when ever there is a deformation in spacetime, doesn't it also create a minute time dilation? So in a laser based detector, even if the distance between the objects change when a gravitational wave passes, doesn't the time dilation affect the time taken by the laser to travel between the objects and make it a constant?
Edit
Later I read this What makes us think we can actually detect gravitational waves? as well. But I still think the time dilation argument makes sense.
Here is the metric of the gravitational waves in spherical coordinates (source):
$\eta_{\mu \nu} = \begin{bmatrix} -1 & 0 & 0 & 0 \\ 0 & 1 & 0 & 0 \\ 0 & 0 & r^2 & 0 \\ 0 & 0 & 0 & r^2 \sin^2\theta \end{bmatrix}$
As you can see, it changes only the space coordinates. And only the transversal ones. If there is a change also in the time coordinate, it is not a gravitational wave any more. So, the short answer in the literal sense is a clear no.
But, the gravitational waves are coming from the Einstein Field Eqations by calculating the metric far from the accelerating bodies. Somewhere I've read there are other wave-like gravitational effects with different metric, but they decay with higher powers with the distance from the source. Hopefully somebody with a higher understand in the topic will explain its details.
Extension: Fortunately it already happened in this wonderful answer.
peterh
  • 8,872
