To find the gravity at Schwarzschild radius of a black hole, I used the below equations. Assuming escape velocity at event horizon is speed of light c and M is the mass of the black hole
$$ v_e = \sqrt{\frac{2GM}{r}} = \sqrt{2gr\,} $$ or $$ g = {\frac{v_e^2}{2r}} = {\frac{c^2}{2r}} $$
Now substituting the Schwarzschild radius of ${\frac{2GM}{c^2}}$ for r we get
$$ g = {\frac{c^4}{4GM}} $$
Just thinking on a time dilation perspective, I have also read that acceleration can not be distinguished from gravity. So if I can accelerate a body with a rocket at above rate will it cause same time dilation like a black hole? And if at all the answer is yes, shouldn't such a value be independent of the mass of black hole?
