I'm self-studying Mechanics and I have a little problem:
We can see that in Landau's book or in Wikipedia that when we inject the lagrangian in Euler Lagrange equation the term $\frac{\partial v²}{\partial q}$ vanish. So we get $\frac{\partial L}{\partial q}= - \frac{\partial U}{\partial q}$
here more details :
We want to proof that Euler-lagrange equation imply newton law :
Euler lagrange equation state that $\frac{d}{dt}\frac{\partial L}{\partial \dot{q}} = \frac{\partial L}{\partial q}$
And $ L= T-V(q)= \frac{1}{2}mv² - V(q) $
But if we inject L in Euler-Lagrange equation we will get
$\frac{d}{dt}\frac{\partial L}{\partial \dot{q}} = m\frac{dv}{dt} - \frac{d}{dt}\frac{\partial V}{\partial \dot{q}}$
And $\frac{\partial L}{\partial q} = \frac{1}{2}m\frac{\partial v²}{\partial q} + F$
In landau's book the terms $\frac{\partial V}{\partial \dot{q}}$ and $ \frac{1}{2}m\frac{\partial v²}{\partial q}$ Vanish without any explanation
Why these terms vanish?
The first term vanishes because you have assumed that the potential is independent of $\dot{q}=v$ (as you have said, $V(q)$). The second term vanishes because speed and possition are independent.
Someone
The Lagrangian is defined in the most simple case as a function of $q$, $\dot{q}$ and $t$: $L(q,\dot{q},t)$. This notation implies that $q$, $\dot{q}$ and $t$ are by definition independent variables. This is how you have to interpret the partial derivatives to $q$ and $\dot{q}$, it doesn't make sense to write: $q = f(\dot{q})$, because both are considered independent variables in the lagrangian. Its just a function of three variables, so $\frac{\partial L(q,\dot{q},t)}{\partial \dot{q}}$ is mathematically just the same as $\frac{\partial L(x,y,t)}{\partial y}$ where we replaced $q$ by $x$ and $\dot{q}$ by $y$: it is the derivative to the second variable of the function.
Ofcourse when you solve the problem and find a $q(t)$ you can find a relation for this solution between $q$ and $\dot{q}$: $q = f(\dot{q})$, but this doesn't alter the fact that you should consider the variables of the $L$ above as independent, this solution has nothing to do with the independent variables of the lagrangian.
So when using the Lagrange formula: $$\frac{d}{dt}\frac{\partial L(q,\dot{q},t)}{\partial \dot{q}} = \frac{\partial L(q,\dot{q},t)}{\partial q}$$ the idea is that for the partial derivatives you just look at $q$ and $\dot{q}$ as independent variables, neglecting possible solutions you may have in mind. Calculating these derivatives will result in new functions of $q$, $\dot{q}$ and $t$, f.i.: $F(q,\dot{q},t) =\frac{\partial L(q,\dot{q},t)}{\partial \dot{q}}$. Then you have to calculate a total derivative to $t$ of $F$: to do this you have to substitute a possible solution $q(t)$, i.e. $F \circ q = F(q(t),\dot{q} (t),t) = G(t)$, the result is a function of only $t$, only when calculating this total derivative you can use dependency between $q$ and $\dot{q}$ because you have to insert a possible solution.
yarnamc
  • 1,281
If
$$L = \frac{mv^2}{2} - V(q) = \frac{m(\dot q)^2}{2} - V(q)$$
Then
$$\frac{\partial L}{\partial \dot q} = m \dot q$$
Why? Because $V(q)$ is a function of $q$ thus the partial derivative of $V$ with respect to $\dot q$ is zero.
Similarly
$$\frac{\partial L}{\partial q} = -\frac{\partial V}{\partial q}$$
Why? Because $\frac{m(\dot q)^2}{2}$ is a function of $\dot q$ thus the partial derivative of $\frac{m(\dot q)^2}{2}$ with respect to $q$ is zero.
