What is the experimental value of the ratio between the proton and the electron charge? Or more generally, is there a table that lists the ratio of the different nuclei charges to that of the electron?
Nikos M.
  • 5,302
[PDG] quoted something like $(q_p+q_e)/e$ without defining these quantities,
That is exactly what you asked for. Recall that the charge on the electron $q_e$ is negative and that on the proton $q_p$ is positive, so the sum there is exactly the difference in their magnitudes. Taking it as a fraction of the defined base charge $e$ makes it a dimensionless value that does not depend on units, and $$ \frac{\left| q_p + q_e\right|}{e} \le 1 \times 10^{-21}$$ is a pretty good measurement.
