If I change units of an angle for radians to degrees in the next expresion $$4\sin (\theta) \frac{d \theta}{d t}=\frac{dy}{dt}$$ the value of $$\frac{dy}{dt}$$ changes.
For example at a rate of change of $\frac{d\theta}{dt} = 30deg , \qquad $ and $\frac{d\theta}{dt}=\frac{\pi }{6}rad$ the rate of change is the same, but the final expresion is not.
So which is the correct unit? and mathematicaly why is the reason?.
I already know that the correct unit are radians, Im looking for a more formal and deeper explanation of why this units are the correct.
Thanks
