I have studied in Introduction to electrodynamics (Griffiths) that magnetic field is actually due to effects of relativity
unequal Lorentz contraction of the positive charge and negative lines, a current- carrying wire that is electrically neutral in one inertial system will be charged in another.
(this was ,'as explained in Griffiths.)
But here (MIT website, chapter 9, http://ocw.mit.edu/courses/physics/8-02t-electricity-and-magnetism-spring-2005/lecture-notes/ ) I have seen,
a single charge also produces magnetic field
but how this is possible? How can I imagine contraction of single charge (not a line of charge).
Paul
  • 3,475
According to the Lorentz transformations of the electric and magnetic fields, there is also a magnetic field in a frame of reference moving relative to another frame of reference in which there is just a static electric field.
So, assuming an isolated point charge, in the frame of reference in which the charge is at rest, there is only a static, radially directed electric field.
But, in a relatively moving frame of reference, there is also a magnetic field.
Put another way, it isn't that we apply the Lorentz transformation to the electron and then calculate the field, we apply the Lorentz transformation to the electromagnetic field over all space.
The case of a neutral wire with steady current is a special case with a symmetry that allows us to derive some results without directly applying the Lorentz transformation to the fields themselves.
In summary, to understand the answer to your question fully, you must appreciate that the electric and magnetic fields themselves transform according to the Lorentz transformations - relatively moving observers 'see' different electric and magnetic fields.
Update:
Since you are reading Griffiths' "Introduction to Electrodynamics", please see Example 12.15 (of the 4th edition) Magnetic field of a point charge in uniform motion where Griffiths derives the magnetic field by transforming from the static electric field of the point charge's rest frame into a relatively moving frame.
Related How do moving charges produce magnetic fields?
A moving charge $q$ with velocity $\vec{v}$ produces a current
$$\vec{j}=\rho(r) \vec{v}$$
($\rho$ charge density associated to charge $q$, $\vec{j}$ current density, ref)
and by Maxwell's equation for the magnetic field (Ampere Law):
$$\nabla \times \vec{B} = \mu_0\vec{J} + \partial \vec{E}/\partial t$$
Magnetic field is produced.
In special relativity (inertial frames), in a moving frame of the charged partile, the magnetic field calculated above can also be seen as the relativistic correction to the electrostatic field of the rest frame.
A Lorentz transformation makes this explicit.
Nikos M.
  • 5,302
A single charge cannot produce a static magnetic field. It can produce a time-dependent magnetic field. It is also a relativity effect because both electric and magnetic fields are changed with change of the reference frame.
In a moving reference frame (or when the charge moves) one observes not only electric, but also a magnetic field $\mathbf{H}'\propto\mathbf{V}\times\mathbf{E}$
