Grassmann variables were introduced to make path-integral formalism easier to handle fermionic (anti-commutating) fields.
Mathematically they represent the exterior algebra of forms (or exterior derivatives).
Furthermore they can be represented (matrix representation theory) as matrices of dimension $2^n \times 2^n$.
However a similar concept is found in complex numbers which have both a matrix representation and a geometric one (as $2$-dimensional vectors).
What is the geometric representation/interpretation of a Grassmann number (even in higher dimension if needed)?
More specificaly what would be the geometric intepretation of $\theta^2=0$?
For example a mixed number of the form $a+b\theta$ (in geometric analogy to complex number)
Nikos M.
  • 5,302
Since no answer is provided thus far, I will attempt at a tentative answer along geometric lines.
The answer is based on EPH-classifications in Geometry, Algebra, Analysis and Arithmetic and exposes a basic trichotomy in Geometry, Algebra, Analysis and Arithmetic between Elliptic equations/spaces, Parabolic equations/spaces and Hyperbolic equations/spaces (that goes back to ancient greek mathematics on classifications of conic sections).
Specificaly:
Trichotomy of Elliptic-Parabolic-Hyperbolic appears in many different areas of mathematics. All of these are named after the very first example of trichotomy, which is formed by ellipses, parabolas, and hyperbolas as conic sections. We try to understand if these classifications are justified and if similar mathematical phenomena is shared among different cases EPH-classification is used.
At first glance EPH-classification is nothing deep. A discriminant of a quadratic form being negative, zero or positive should not be that important for people to make so much fuss about it. Geometric similarity between the zeros of quadratic forms in affine space, could be a motivation for naming them differently. But why is it that the elliptic, parabolic, hyperbolic names are used so widely in mathematics, in places where it seems irrelevant to the shape of hyperbola, parabola and ellipse? The question is, does there exist a paradigm behind these namings.
Of interest is that complex numbers are related to elliptic spaces, dual numbers (grassmann numbers) to parabolic spaces and usual numbers to hyperbolic spaces.
[..]We shall justify below why ”Elements of $SL_2(R)$” are named elliptic, parabolic, and hyperbolic after the original paradigm of conic sections. ”Actions of $SL_2(R)$ on complex numbers, double numbers, and dual numbers” are also related to the geometry of conic sections.
[..]A key part of the study of Mobius transformations is their classification into elliptic, parabolic and hyperbolic transformations. The classification can be summarized in terms of the fixed points of the transformation, as follows: Parabolic: The transformation has precisely one fixed point in the Riemann sphere. Hyperbolic: There are exactly two fixed points, one of which is attractive, and one of which is repelling. Elliptic: There are exactly two fixed points, both of which are neutral. Now we turn to studying the connection between Mobius transformations and conic sections. The transformations we consider are those that preserve the unit disk . It is straightforward to see that all such Mobius transformations correspond to matrices in $SU(1, 1)$. Given such a matrix , the Mobius transform maps the unit disk into itself in such a way that it maps arcs orthogonal to the unit circle to arcs orthogonal to the unit circle. These transforms are in fact the isometries of the Poincare disk.
[..]The $SL_2(R)$ action by Mobius transformations is usually considered as a map of complex numbers $z = x + iy, i^2 = −1$. Moreover, this action defines a map from the upper half-plane to itself. However there is no need to be restricted to the traditional route of complex numbers only. Less-known double and dual numbers also have the form $z = x + iy$ but different assumptions on the imaginary unit $i$: $i^2 = 0$ or $i^2 = 1$ correspondingly. Although the arithmetic of dual and double numbers is different from the complex ones, e.g., they have divisors of zero, we are still able to define their transforms by Mobius transformations in most cases. Three possible values $-1, 0$, and $1$ of $\sigma = i^2$ will be referred to here as elliptic, parabolic, and hyperbolic cases respectively.
[..]To understand the Mobius action in all EPH cases, we use the Iwasawa de- composition of $SL_2(R) = ANK$ into three one-dimensional subgroups $A, N, K$: $\begin{pmatrix}a & b\\\ c & d\end{pmatrix} = \begin{pmatrix}k & 0\\\ 0 & k-1\end{pmatrix} \begin{pmatrix}1 & w\\\ 0 & 1\end{pmatrix} \begin{pmatrix}Cos \theta & −Sin \theta\\\ Sin > \theta & Cos \theta\end{pmatrix}$.
Subgroups $A$ and $N$ act in (1) irrespective of the value of $\sigma$: $A$ makes a dilation by $α^2$, i.e., $z \rightarrow α^2z$, and $N$ shifts points to left by $ν$, i.e. $z \rightarrow z + ν$. By contrast, the action of the third matrix from the subgroup $K$ sharply depends on $\sigma$. In the elliptic, parabolic and hyperbolic cases K-orbits are circles, parabolas and (equilateral) hyperbolas correspondingly.
[..][Riemann’s] uniformization theorem says that every simply connected Riemann surface is conformally equivalent to one of the three domains: the open unit disk, the complex plane, or the Riemann sphere. In particular it admits a Riemannian metric of constant curvature. This classifies Riemannian surfaces as elliptic (pos- itively curved rather, admitting a constant positively curved metric), parabolic (flat), and hyperbolic (negatively curved) according to their universal cover. The uniformization theorem is a generalization of the Riemann mapping theo- rem from proper simply connected open subsets of the plane to arbitrary simply connected Riemann surfaces.
[..]From this, a classification of metrizable surfaces follows. A connected metriz- able surface is a quotient of one of the following by a free action of a discrete subgroup of an isometry group: 1.the sphere (curvature +1) 2.the Euclidean plane (curvature 0) 3.the hyperbolic plane (curvature −1).
Nikos M.
  • 5,302
I would like to add that the $(1, e) $ Grassman algebra with $e^2=0$ permits an interpretation in terms of Galilean transformations, like what the previous answer wrote. This is analogous to complex numbers
Also,the higher dimensional exterior algebra $(1, e_1, e_2, e_3.....) $ can be geometrically interpreted in terms of multivectors : oriented planes in higher dimensions. The magnitude of the wedge product is the determinant of the vectors in the wedge product.
The anticommutative structure $e_ie_j=-e_je_i$ encodes determinants. The idea is the same as in cross products: The length $|\vec{a}\times \vec{b}|$ gives you the area of the parallelogram, while the direction gives you the orientation of the parallelogram. But the cross product does not generalise to higher dimensions.
Cross product defines $e_1\times e_2=e_3$. This definition is possible in three dimensions. In higher dimensions, you don't have a unique vector that is orthogonal to both multiplicands.
Instead, we just define $e_1e_2=e_1\wedge e_2$ as a mathematical object that directly represents the orientation of the plane $(x, y) $. $e_1e_4$ represents the orientation of the plane $(x,w) $ etc. Linear combinations like $e_1e_2+e_1e_3$ represent the plane $e_1 \wedge (e_2+e_3)$.
$(e_1+e_4) \wedge (e_2+e_1) \wedge e_3$ represents a 3D parallelopiped, oriented in 4D space.
Ryder Rude
  • 6,915
